![]() | Home > Maintenance & Modifications > Exhaust Tips Rattling against Rear Vibration Damper |
You can try and alter the fit when you tighten the clamp, helped a little with mine but I still ended up holding one pipe with my hands whilst pushing the other away with my feet. That got it spot on. 2019 5.0 SC SVA (Current)
[But I still ended up holding one pipe with my hands whilst pushing the other away with my feet. That got it spot on.]
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I bought some Hawke exhaust tips in 2010 when my TDV8 was new. There was not enough clearance with the right hand balancer (it touched all the time) so they went straight back in the box. I had about 6-7mm clearance between the balancer and the exhaust. |
I fitted a set of tail pipe trims to a 2008 Sport I use to own. however I did not want the exhaust gasses exiting from underneath the trim as I thought it looked |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I had exactly the same problem with my exhaust tips from eBay. The left hand one fouled the resonating damper. In the end I fitted them with the nearside one just very slightly off the horizontal plane and mirroring the slant the other way on the offside one. Of course I can see it and its annoying - but to the casual observer I believe it looks acceptable.
03184 Member Since: 11 Jul 2018 Location: Alicante Posts: 63 ![]() ![]() ![]() |
I think this is a common problem, I bought a pair from powerfuluk and ended up by physically (using foot) pushing it until it stopped rattling. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
