Home > Technical > CD Player not working
Tiny Timmy
Hi, My CD player wont accept a Disc, just keeps saying "insert Disc".!!and wont eject anything either.
When I look through the CD slot I can see a Barcode sticker and what looks like the silver side of the unit ???!!!
Can anyone help?? Its a 2012 RRS
Post #582410 Fri Jun 14 2019 2:22pm
Brit Plumber
Is the issue when you try and put a disc in?
Jus to eliminate one issue I know of with the 2012MY, can you flip out the cover plate around the opening? I have a plastic tool for this job but I suppose a credit card or something in the gap at the bottom and prising it out would work. Then try inserting/removing a disc. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582428 Fri Jun 14 2019 10:23pm
Themoog
Our cd player on the dash won't work either. It's a 2005 supercharged and from what I have researched they break inside or something which stops it accepting discs. I did have a quote of £90 to repair it but never bothered. It's radio 2 if the wife is in it, kiss fm if the wife and kids are in it, no radio on and windows down if I'm in it..
Post #582433 Sat Jun 15 2019 5:34am
Tiny Timmy
I'll have a go at that Brit. Just brought it so I'm not sure if it has a disc in or not. But wont take a disc in at all !
But as I say when I look in the slot all I can see is what looks like the side of the unit??.........TT
Post #582434 Sat Jun 15 2019 6:01am
Oldandconfused
If you bought it from a dealer take it back and tell them to fix it. I have just put a load of music on a USB stick and don't use my CD player although mine does work.
Post #582436 Sat Jun 15 2019 7:05am
Tiny Timmy
Ah maybe the USB stick could be the way for me?? Smile Would be less hassle
Post #582438 Sat Jun 15 2019 8:03am
Brit Plumber
The unit is set back behind the trim, so looking through you should see it. You won’t see a CD though unless you look when/if it tries to eject one. If it fails to eject, it will take it back in again. Common issue is when the centre console and dash trim piece (the one with the clock) aren’t quite sat right together and it distorts the grey pop out trim enough to block the CD. 2019 5.0 SC SVA (Current)
Post #582441 Sat Jun 15 2019 8:21am
Inserting discs is not simple.
In early cars. First you need to tell it which if the 6 slots you want it to go in.
Read the manual. It may not be broken
Post #582442 Sat Jun 15 2019 8:38am
Brit Plumber
The OPs car is a 2012 so has the virtual changer but you can play straight from the disc by inserting it, nothing else needed. 2019 5.0 SC SVA (Current)
Post #582443 Sat Jun 15 2019 8:45am
Tiny Timmy
Yeah Brit I cant see anything, just as i say what looks like the side of the unit with a bar code on it .
Nothing happens when I press eject except the noise( of ejecting ).
There may not be a CD in there as it is saying "insert a CD ".
Bit of a strange one
Post #582455 Sat Jun 15 2019 11:24am
