![]() | Home > Technical > CD Player not working |
Is the issue when you try and put a disc in?
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Our cd player on the dash won't work either. It's a 2005 supercharged and from what I have researched they break inside or something which stops it accepting discs. I did have a quote of £90 to repair it but never bothered. It's radio 2 if the wife is in it, kiss fm if the wife and kids are in it, no radio on and windows down if I'm in it.. |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
I'll have a go at that Brit. Just brought it so I'm not sure if it has a disc in or not. But wont take a disc in at all !
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
If you bought it from a dealer take it back and tell them to fix it. I have just put a load of music on a USB stick and don't use my CD player although mine does work. |
Ah maybe the USB stick could be the way for me?? |
The unit is set back behind the trim, so looking through you should see it. You won’t see a CD though unless you look when/if it tries to eject one. If it fails to eject, it will take it back in again. Common issue is when the centre console and dash trim piece (the one with the clock) aren’t quite sat right together and it distorts the grey pop out trim enough to block the CD. 2019 5.0 SC SVA (Current)
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Inserting discs is not simple.
The OPs car is a 2012 so has the virtual changer but you can play straight from the disc by inserting it, nothing else needed. 2019 5.0 SC SVA (Current)
Yeah Brit I cant see anything, just as i say what looks like the side of the unit with a bar code on it .
