![]() | Home > General > curiosity has ogt the better of me..... winch options |
I believe your options are very limited on the facelift, I think you might need to wait until someone like Buckster or RRSTDV8 come along.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Not cheap, that's for sure! I was lucky enough to get my (pre-facelift) OE parts second hand though un-used off a member on here but that included a bumper with the relevant cutouts too. |
Buckster has one on his facelift L320. Hopefully he can give you some pointers. 2012 SDV6 - it's missing a couple of cylinders
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Thanks all, hopefully Buckster can advise.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
O/T - how are you getting on with your Easylift, Pufftmw? |
Not installed it yet. Have an issue with ARC controller and waiting for that to get fitted/working and my lean error to go. Didn't want to complicate things.
Great. I haven't worn out the compressor yet! |
Just out of interest, what sort of rating is appropriate to a RRS?
I think the G4 winch was rated at 9000lb or just over 4 tonnes. 2012 SDV6 - it's missing a couple of cylinders
Thanks, Wayne. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
wildbear do a discreet mount but requires a bumper cut. (looks very discreet though if done right
The image Wildbear use to illustrate their mount (e.g., on eBay) looks to be of exactly the same car that FirstFour use to illustrate what they label as Britpart.
Well Britpart are a parts distributor and Wildbear are a fabricator. I'll leave you to work out what may or may not be the link there. Andy at Wildbear is a lovely guy to talk to. 2012 SDV6 HSE (technically its hers)
