Home > General > curiosity has ogt the better of me..... winch options
Page 2 of 3 <123>
HughN
Wales
Ah, OK. Wink
A 12,000 lb winch is probably the thick end of 5 kW so would probably require 70 mm² cable to handle the 400 (or more) Amps.
Post #582235 Wed Jun 12 2019 7:00am
Duc750
I'd check the numbers as it depends on whether the rating is achieved through motor or gearing
I have a FROM Edge 12.5K on the D2 and the stall current is 357 Amps - the 9.6K is 329 Amps same motor in both but gearbox is different
Now the amount of times you would stall a winch is pretty low on a 12.5K winch (and still fairly low on a 9.6K winch) but I would argue the difference there is not whats deciding your cable sizes - that should be the acceptable transmission loss at somewhere around 350a for the above two examples.
On my D2 i'm on 70mm2 cable battery to solenoid to winch and fused at 400 amps so I'm over cabled, fused appropriately and all good. I could drop the fuse to 350 (and probably will) when i remember or even as low as 300 amps as blow rating is twice continuous current on most fuses 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #582239 Wed Jun 12 2019 9:13am
Buckster
Sorry only just seen this! Embarassed there are several options available.
1: Warn External Winch tray as fitted to mine. They are exactly the same tray as a Disco 3 and 4, but you will need the tray and all the associated brackets. I then used a Warn 9.5 XP Synthetic winch, Warn solenoid and Warn cabling for a wireless or cable remote to be used. The trays do occasionally come up for sale on fleebay. This was the set up used on the G4 challenge cars built by Land Rover and is still available new.
2: Devon 4x4 do a discrete Winch mount that sits behind the front bumper, i have never looked to much at this option as i dont like the idea of the Winch being hidden, and not easily being able to clean the winch after being caked in mud. Also the change over spooling leaver is buried in the front bumper so if it somehow became damaged it wouldn’t be easily accessible if you needed it. Also you cannot cover the winch when not in use as its behind the bumper.
The next problem you have is winch guards, as no one makes these for a Facelift car. Mine was an original Mantec guard that came off a Facelift Land Rover Experience car, i then modified it to suit my external set up on the Facelift car.
Im sure i done abit of a write up after completion so will see if i can find the thread Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #582243 Wed Jun 12 2019 11:04am
Buckster
https://www.rrsport.co.uk/forum/topic48878.html?highlight=winch 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #582245 Wed Jun 12 2019 11:07am
HughN
Wales
Not 'plug-and-play', then!
Killer question - how often have you used it in anger? Very Happy
Post #582301 Thu Jun 13 2019 6:52am
Pufftmw
Quite a few times now - mainly pulling my tractor out of a muddy field Big Cry
Post #582381 Fri Jun 14 2019 6:24am
Buckster
Been used for recovery of others more than myself, but for me the main reason for fitting was for solo trips abroad, so i know I can get myself out of trouble should i need too. Also makes a good parking aid Laughing Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #582400 Fri Jun 14 2019 11:46am
Duc750
I'd agree with the winch being for others mainly. problem is seldom do you want to pull yourself forward , further into what you got stuck in.
The winch is really only on my D2 for when we're solo with the trailer as being pulled backward is not really an option.
Doesn't stop me working out how to put one on her RRS though Smile 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #582414 Fri Jun 14 2019 3:08pm
Buckster
Any questions you have i will do my best to answer Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #582415 Fri Jun 14 2019 3:49pm
Duc750
Actually on a side topic Buckster, your RAI, did you have to modify it any to fit yours as its only listed as fitting up to 09 according to landrover 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #582416 Fri Jun 14 2019 4:06pm
Buckster
Yes modified to fit and sealed for waterproofing, but if your in that deep you are floating Rolling with laughter All modified just like everything else on a facelift car Big Cry I did buy a brand new rear ladder but it was way to much aggro to modify it and I just didnt have the time so i gave up with that Rolling Eyes 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #583081 Wed Jun 26 2019 2:35pm
Duc750
don't suppose you have any details of the mods do you ? 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #583090 Wed Jun 26 2019 4:19pm
HughN
Wales
I've just fitted an el cheapo RAI clone on my "classic" (i.e., pre-facelift) car, partly because a day on a dusty Salisbury Plain left the air-box absolutely full of Censored (and because it looks 'cool').
In terms of water-proofing, the only time I have been slightly worried in my pre-RAI car was when crossing a river with a slight current coming from the driver's side, at the depth of the side vent and thus potentially into the air intake.
Various expensive electronic bits will be ruined before it becomes a true snorkel!
Post #583093 Wed Jun 26 2019 4:25pm
Duc750
Similar thing to be honest. when in the Alps/Cevenne/Piedmont last year the RAI on the Disco saved me having to do a filter swap over the weeks we were away. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #583098 Wed Jun 26 2019 4:54pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
our MY10 3 Litre oil burner with RAI (was sealed but since servicing assume it needs doing again),
Roo Bar and Warn Winch.. full underbody protection including Rock Sliders and Step out bars
(for those pesky rocks).. its been to Cape York the hard way ..
The RAI is a god send when using the unsealed roads, the amount of bull dust that is
stirred up is nothing short of amazing, and gets in everywhere.
 Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #583354 Mon Jul 01 2019 7:10am
Page 2 of 3 <123>
