Home > General > curiosity has ogt the better of me..... winch options
Page 1 of 3 123>
PC76
Ok so not something i am and going to do straight away (possibly never depending upon cost..) but........
What options are there for fitting winches to the L320 2010 sport?
Post #581705 Fri May 31 2019 7:50pm
I believe your options are very limited on the facelift, I think you might need to wait until someone like Buckster or RRSTDV8 come along.
Post #581708 Fri May 31 2019 11:09pm
Pufftmw
Not cheap, that's for sure! I was lucky enough to get my (pre-facelift) OE parts second hand though un-used off a member on here but that included a bumper with the relevant cutouts too.
Post #581712 Sat Jun 01 2019 8:08am
Buckster has one on his facelift L320. Hopefully he can give you some pointers. 2012 SDV6 - it's missing a couple of cylinders
Post #581724 Sat Jun 01 2019 9:48am
PC76
Thanks all, hopefully Buckster can advise.
I wouldn't mind having it done ready for winter if i can afford it as i am now a volunteer responder for 4x4 Rescue North Wales..
Post #581727 Sat Jun 01 2019 11:50am
Pufftmw
Post #581729 Sat Jun 01 2019 1:12pm
HughN
Wales
O/T - how are you getting on with your Easylift, Pufftmw?
Post #581738 Sat Jun 01 2019 3:16pm
Pufftmw
Not installed it yet. Have an issue with ARC controller and waiting for that to get fitted/working and my lean error to go. Didn't want to complicate things.
Stuff doesn't happen quickly around where I am and I'm not in too much of a rush.
How about you?
Post #581756 Sat Jun 01 2019 8:42pm
HughN
Wales
Great. I haven't worn out the compressor yet!
Post #581759 Sun Jun 02 2019 4:41am
HughN
Wales
Just out of interest, what sort of rating is appropriate to a RRS?
Thks
Hugh
Post #582149 Mon Jun 10 2019 7:15am
I think the G4 winch was rated at 9000lb or just over 4 tonnes. 2012 SDV6 - it's missing a couple of cylinders
Post #582161 Mon Jun 10 2019 11:07am
HughN
Wales
Thanks, Wayne. Thumbs Up
Post #582162 Mon Jun 10 2019 11:17am
Duc750
wildbear do a discreet mount but requires a bumper cut. (looks very discreet though if done right
9000lbs feels low for a RRS unless you are carrying extension straps and are happy to double line pull there is no difference in physical size now between most 9K and 12K winches 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #582210 Tue Jun 11 2019 3:45pm
HughN
Wales
The image Wildbear use to illustrate their mount (e.g., on eBay) looks to be of exactly the same car that FirstFour use to illustrate what they label as Britpart.
Confused
Post #582212 Tue Jun 11 2019 6:00pm
Duc750
Well Britpart are a parts distributor and Wildbear are a fabricator. I'll leave you to work out what may or may not be the link there. Andy at Wildbear is a lovely guy to talk to. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #582220 Tue Jun 11 2019 8:03pm
Page 1 of 3 123>
