Home > Maintenance & Modifications > 7yr /112k cambelt service.What would you expect to pay? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
£700 for belts
Wed May 29 2019 6:13pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
I am in the SE corner and it will be approx £1200 this will include a couple of small jobs that
Wed May 29 2019 6:14pm |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 |
Thanks Chaps
Thu May 30 2019 6:59pm |
What quotes are you having, and is the work quoted for "like-for-like"?
Thu May 30 2019 7:20pm |
Or you could get the back belt done as I did when the body was off to replace the turbos... It's easier to reach then . Had front done 6 months later on schedule. |
Thu May 30 2019 7:27pm |
Hi Mike
Thu May 30 2019 7:31pm |
Fri May 31 2019 5:04am |
My reason exactly for clarifying the price discrepancy which did not include the High pressure fuel timing belt????Thanks for the heads up buddy.
Fri May 31 2019 4:41pm |
Ive seen the HPFP belt break up, and tear holes in the plastic cover, and then tear chunks out the wiring loom
Fri May 31 2019 6:14pm |
Your not a million miles away from Alltrack 4x4, in Malvern
Fri May 31 2019 6:38pm |
Will do thanks
Sat Jun 01 2019 6:12am |
