![]() | Home > Maintenance & Modifications > 7yr /112k cambelt service.What would you expect to pay? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
£700 for belts
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
I am in the SE corner and it will be approx £1200 this will include a couple of small jobs that
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
Thanks Chaps
What quotes are you having, and is the work quoted for "like-for-like"?
Or you could get the back belt done as I did when the body was off to replace the |
Hi Mike
My reason exactly for clarifying the price discrepancy which did not include the High pressure fuel timing belt????Thanks for the heads up buddy. |
Ive seen the HPFP belt break up, and tear holes in the plastic cover, and then tear chunks out the wiring loom |
Your not a million miles away from Alltrack 4x4, in Malvern
Will do thanks
