![]() | Home > Maintenance & Modifications > Indicator and Wiper Stalks Upgrade |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
Are they a direct plug and play swap out??? 2015 L494 SDV6 3.0 HSE Loire Blue
Yes, straight swap. 5 minutes to fit. Kev
Lucky you. Didn’t think you got Ebay bargains anymore. |
I think it was luck to be honest Andy. I've seen these going for a lot more since. Kev
That’s really smart |
They are the same as the RRS 12MY and are the same as Disco 4. They are also similar to Evoque, Disco Sport, Freelander etc but they have the lights, fogs etc on the left stall. They also have an additional setting on the right stalk for Intermittent rear wipe which I’ve been toying with the idea of trying as it’s one feature I’d like as I do get fed up with looking out of the rear and then having to select rear wipe when I can’t see. 2019 5.0 SC SVA (Current)
The Evoque stalks won't fit mate. They have different connectors....
That’s a |
my old RRS has intermittant rear wiper. (I think it can be changed via IID to constant)
How do you set/change the delay on the rear int setting? Mine is the 12MY but it is on or off with no int setting. 2019 5.0 SC SVA (Current)
so the first thing you need to do is plug the IID in and edit the CCF to set rear as intermittant.
The thumb wheel on the switch (marked MAX) adjust the rear delay (as I have rain sensing front) |
Thanks, I’ve also got rain sensing on mine but the thumb knob sets the time for the front wipe. Do you lose that functionality when you change the CCF? The manual mentions a CCF edit for drip wipe and says the rear wipe changes with vehicle speed but nothing else. I’ll have to have a look and see. 2019 5.0 SC SVA (Current)
Dunno.
