![]() | Home > Technical > Rear Load Cover - How to tell the difference ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Easiest way to tell difference, first picture split tailgate, second picure one piece tailgate.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Im pretty sure mine is the 2nd one . Are there any inserts that are meant to be on the car trim pieces to make it fit snug ?
The length of my cover is 1350mm then the locking lugs stick out about another 10mm each end of cover.
Cheers Col |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Not sure if these help.
Thank you both for the pics , on the underside of mine (Right) there is a little black tab . Is that meant to sit on/within the cars trim panel or on the outside ? |
The black tab is spring loaded and I think somehow lock the cover in place, it does actualy sit in the trim panel so the weight of the cover pushes down on it.
Does this look short to you Col ?
Yes it does, have you measured the length of the cover? perhaps the issue is with the trim panel somehow.
At work atm , but will measure when i get something out of my boot and compare with yours . Many thanks ! |
It does only just locates in the panel but it has never fell out yet.
Cheers Col |
tried both ways , just doesn't seem to fit snug ! |
Ok had a play , size was the same as stated by you. Managed to shift it a bit to the right and it does seem to fit better now . Its not 100% snug , but judging by your pics looks like it now fits the same as yours ![]() |
