Home > Technical > Rear Load Cover - How to tell the difference ?
mrluke
My car is a 2012 and came with a rear load cover.
Problem being is it seems a bit short ! it barely holds on one side , i am either thinking i have an earlier version or maybe missing some sort of insert for the end pieces ?
Any one able to help me out please ?
Post #580727 Mon May 13 2019 12:28pm
Easiest way to tell difference, first picture split tailgate, second picure one piece tailgate.
Post #580732 Mon May 13 2019 1:05pm
mrluke
Im pretty sure mine is the 2nd one . Are there any inserts that are meant to be on the car trim pieces to make it fit snug ?
Any one got a pic of theres in place !
Thanks for the info btw
Post #580734 Mon May 13 2019 1:07pm
mrluke
As you can see one side of mine doesnt reach the end so it drops down
Post #580778 Tue May 14 2019 6:02am
The length of my cover is 1350mm then the locking lugs stick out about another 10mm each end of cover.
Post #580784 Tue May 14 2019 8:11am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Not sure if these help.
 There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #580785 Tue May 14 2019 8:18am
mrluke
Thank you both for the pics , on the underside of mine (Right) there is a little black tab . Is that meant to sit on/within the cars trim panel or on the outside ?
Post #580786 Tue May 14 2019 8:21am
The black tab is spring loaded and I think somehow lock the cover in place, it does actualy sit in the trim panel so the weight of the cover pushes down on it.
Post #580788 Tue May 14 2019 8:33am
mrluke
Does this look short to you Col ?
Thanks for your help as always !
Post #580789 Tue May 14 2019 8:36am
Yes it does, have you measured the length of the cover? perhaps the issue is with the trim panel somehow.
Post #580790 Tue May 14 2019 8:40am
mrluke
At work atm , but will measure when i get something out of my boot and compare with yours . Many thanks !
Post #580791 Tue May 14 2019 8:41am
It does only just locates in the panel but it has never fell out yet. Laughing Which end are you locating first?
Post #580792 Tue May 14 2019 8:50am
mrluke
tried both ways , just doesn't seem to fit snug !
Post #580794 Tue May 14 2019 9:48am
mrluke
Ok had a play , size was the same as stated by you. Managed to shift it a bit to the right and it does seem to fit better now . Its not 100% snug , but judging by your pics looks like it now fits the same as yours Laughing
Post #580796 Tue May 14 2019 11:05am
Thumbs Up Yeah, couldn't be described as a perfect fit.
Post #580798 Tue May 14 2019 11:15am
