Home > Technical > 2012 RRS (1piece tailgate) - Boot sticking ?
mrluke
Any one else have this problem ? seems to happen more when the car is in the sun .
I press the boot release on the key and it pops it up a little then stops.. I press the key again and then it opens.
This doesnt happen all the time, and for some strange reason the button on the dash seems to pop it ok ? ( or it has every time i did it via that instead of the key)
Cant see whats stopping it from popping ! and why its only happening randomly.
Post #580110 Thu May 02 2019 8:33am
Mine used to do that somtimes, seemed to be after parking in the sun, fitted a new switch and been fine ever since.
Post #580118 Thu May 02 2019 9:56am
mrluke
What switch are we talking about Col ?
Dashboard switch ? or the handle switch on the outside ? or another one ?
Post #580119 Thu May 02 2019 10:09am
Hi, sorry yeah should of said the release switch in the tailgate betwen the number plate lamps.
Post #580122 Thu May 02 2019 10:16am
mrluke
seems reasonably cheap, might be a good idea to replace any way Wink
Thanks for the info.
Post #580123 Thu May 02 2019 10:21am
Brit Plumber
I don’t mean to teach you to suck eggs but you haven’t accidentally set the boot opening limit to that position have you? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580124 Thu May 02 2019 10:44am
mrluke
Dont believe i have ? sometime it opens correctly and sometimes it doesn't.
How do i set the boot limiter ?
Post #580128 Thu May 02 2019 11:42am
http://www.rrsport.co.uk/forum/topic52462.html
Post #580129 Thu May 02 2019 12:02pm
mrluke
Thanks for that , Will try that also .
Seems weird how it doesnt always do it and i think it always works correctly from the button on the dash ?
Also i didnt mention i also have the tailgate mod
https://www.ebay.co.uk/itm/Range-Rover-Evo...ctupt=true
But ! i think this has happened before fitting the above !
Post #580131 Thu May 02 2019 12:08pm
Brit Plumber
Agh, the tail gate mod, I have it too and mine does the same thing if I press the button twice by accident. I know the moment I’ve done it, usually when (out of bad habit) I’ve been impatient. Probably something to do with the timer and switch relay in the MOD box. Never does it on the cabin switch as it’s a more positive switch for me. 2019 5.0 SC SVA (Current)
Post #580152 Thu May 02 2019 8:31pm
Sure mine was doing it before fitting similar mod, must be a least 3 years since that was fitted but yours's may be a different problem to the one I had, but as I say a new tailgate switch cured my issue.
Post #580158 Thu May 02 2019 9:14pm
Brit Plumber
A new improved version of the mod came out last year Col, I assume yours needed some wiring in? The guy who makes them told me he had refined it from the original wired in version to the plug and play version in 2018 (I am, maybe incorrectly assuming the OP purchased his recently).
It may worth removing the mod to see if the fault disappears. 2019 5.0 SC SVA (Current)
Post #580162 Thu May 02 2019 10:39pm
I haven't got the fault anymore and the mod never caused it because it was there before the mod was fitted in 2016, my kit came from a forum member who made them (the_big_1) and has been faultless, as I say I replaced the tailgate switch by the number plate lamps not the button in the bottom of the tailgate and it cured my issue, although I think L/R may have revised their original switch.
http://www.rrsport.co.uk/forum/topic43885.html
Post #580164 Thu May 02 2019 10:54pm
Brit Plumber
Yeah that’s the first version, the new version is plug and play so it may be the new version which has a timing issue, not a fault, just something that happens if you accidentally (whether you know it or not) press the unlock button twice. 2019 5.0 SC SVA (Current)
Post #580170 Fri May 03 2019 7:29am
mrluke
Ok i did do the reset last night ( after it failed to open )
I opened the boot this morning and its fine with the key
I will check tonight on the way home , Im pretty sure this happened a few times before i even fitted the mod !
Will check to see if this has fixed the issue and update.
Post #580173 Fri May 03 2019 8:25am
