Home > Technical > 2012 RRS (1piece tailgate) - Boot sticking ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Mine used to do that somtimes, seemed to be after parking in the sun, fitted a new switch and been fine ever since.
Thu May 02 2019 9:56am |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
What switch are we talking about Col ?
Thu May 02 2019 10:09am |
Hi, sorry yeah should of said the release switch in the tailgate betwen the number plate lamps.
Thu May 02 2019 10:16am |
seems reasonably cheap, might be a good idea to replace any way
Thu May 02 2019 10:21am |
I don’t mean to teach you to suck eggs but you haven’t accidentally set the boot opening limit to that position have you? 2019 5.0 SC SVA (Current)
Thu May 02 2019 10:44am |
Dont believe i have ? sometime it opens correctly and sometimes it doesn't.
Thu May 02 2019 11:42am |
Thu May 02 2019 12:02pm |
Thanks for that , Will try that also .
Thu May 02 2019 12:08pm |
Agh, the tail gate mod, I have it too and mine does the same thing if I press the button twice by accident. I know the moment I’ve done it, usually when (out of bad habit) I’ve been impatient. Probably something to do with the timer and switch relay in the MOD box. Never does it on the cabin switch as it’s a more positive switch for me. 2019 5.0 SC SVA (Current)
Thu May 02 2019 8:31pm |
Sure mine was doing it before fitting similar mod, must be a least 3 years since that was fitted but yours's may be a different problem to the one I had, but as I say a new tailgate switch cured my issue.
Thu May 02 2019 9:14pm |
A new improved version of the mod came out last year Col, I assume yours needed some wiring in? The guy who makes them told me he had refined it from the original wired in version to the plug and play version in 2018 (I am, maybe incorrectly assuming the OP purchased his recently).
Thu May 02 2019 10:39pm |
I haven't got the fault anymore and the mod never caused it because it was there before the mod was fitted in 2016, my kit came from a forum member who made them (the_big_1) and has been faultless, as I say I replaced the tailgate switch by the number plate lamps not the button in the bottom of the tailgate and it cured my issue, although I think L/R may have revised their original switch.
Thu May 02 2019 10:54pm |
Yeah that’s the first version, the new version is plug and play so it may be the new version which has a timing issue, not a fault, just something that happens if you accidentally (whether you know it or not) press the unlock button twice. 2019 5.0 SC SVA (Current)
Fri May 03 2019 7:29am |
Ok i did do the reset last night ( after it failed to open )
Fri May 03 2019 8:25am |
