![]() | Home > Technical > Al;arm issues |
FuerteRRS Member Since: 13 Apr 2019 Location: LA OLIVA Posts: 6 ![]() ![]() ![]() |
Hi folks
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
bonnet switches in the latch do give these problems
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
If you disconnect the switch to see if that is the problem, I think you have to bridge the wiring out to complete the circuit otherwise it will still think the bonnet is open.
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
replace bonnet catches cheap fix about £20.00 on ebay
Thanks guys, I have tried bending the lever arm on the micro switch but, will order new switch. |
