![]() | Home > Technical > Auto headlights staying on RRS 2010 |
How dirty is your windscreen? 2019 5.0 SC SVA (Current)
monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28 ![]() |
Thanks for the reply.
be interesting to see if the auto wipers work when it rains.
They are the sams senor and it may need resealing to the screen |
So I’ve poured some water over the windscreen and the wipers work. But it seems they just keep wiping after the windscreen is clean.
I guess what u need to do is position the rear view mirror in the middle. Position.
So I’ve removed the mirror housing and checked the sensor. Everything seems fine and all connections are good. I’ve noticed that while I place the wiper is auto mode they wipe intermittently. Even if there’s no water on the screen.
Arh so maybe it knows the sensor is duff and reverts back to intermittent wipers. and lights on.
So the car has been to Land Rover garage today as it’s covered by extended warranty.
Don’t you just love dealers.
They can’t find any fault so they won’t do any work.
Will they guarantee it WILL fix it? Sounds a bit of a guess to me. Just a thought, how long have you had it? Has it worked before? Has it got a genuine LR front screen. Heard of lots of issues with after market screens not working with some sensors. Big problem on BMWS. 2019 5.0 SC SVA (Current)
Ive had it 2.5yrs. No other problems with it before. It was working up
I’m back home next week so will look at the wiring diagrams. Maybe a bad earth at the base of the A pillar. Have you got a sun roof? 2019 5.0 SC SVA (Current)
