![]() | Home > General > 2005 TDV6 - crappy start |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
more likely to be an injector fault.
As Andy above has said, may be injector. Do have smoke on start up idle?. Are you able to tap somebody with an IID tool to read any codes.
airc909 Member Since: 28 May 2018 Location: Coventry Posts: 112 ![]() ![]() ![]() |
thanks guys. really appreciate it.
Well that but sounds like GPS but they can be a nightmare to change in these |
atpsrrs Member Since: 24 Aug 2017 Location: North Wales Posts: 6 ![]() ![]() ![]() |
did you get the sports to an IID Tool? curious to see what the prob is as mine been odd at starting on first start up in the morning, when it was plugged in it read the following faults:
