Home > General > 2005 TDV6 - crappy start
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
hi all
my 2005 rrs tdv6 is starting a bit crappy at the mo, wondering if it might be battery or glow plugs
when i start it from cold, it turns over strong then generally fires into life but tends to bottom out and cut out unless i rev it for a couple of seconds
i obviously wait for the glow plug light to go out before i start it
its the 2.7 tdv6
thanks
chris
Post #578409 Thu Apr 04 2019 2:36pm
more likely to be an injector fault.
GP's only tend to show up as a problem below 1°C
Post #578415 Thu Apr 04 2019 4:55pm
Stevepd
As Andy above has said, may be injector. Do have smoke on start up idle?. Are you able to tap somebody with an IID tool to read any codes.
I had something similar and was warned by my indie that it may need a #1 injector as it was near the upper limit. On his suggestion I put 3 tank fulls of BP Ultimate (Shell is too far away) and cleared the codes. It now idles very smoothly and no codes reappeared some 7 weeks later.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #578427 Thu Apr 04 2019 7:10pm
airc909
thanks guys. really appreciate it.
yes bit of smoke when i floor it from cold
i will get it plugged in
when it was really cold a few weeks ago there was a couple of mornings where it didnt start at all. was turning over strong but not firing which is why i thought it might by GP
i will report back when i know more as i want to keep the old girl running, such a useful tool!
Post #578447 Fri Apr 05 2019 8:07am
Well that but sounds like GPS but they can be a nightmare to change in these
Post #578452 Fri Apr 05 2019 11:00am
atpsrrs
Wales 2005 Range Rover Sport TDV6 S Arctic Frost
did you get the sports to an IID Tool? curious to see what the prob is as mine been odd at starting on first start up in the morning, when it was plugged in it read the following faults:
P0405-00 (2C) Exhaust gas recirculation sensor A - circuit low
P02AA-00 (6Cool Cylinder 5 balance - fuel trim at maximum limit
P121A-00 (6Cool Cylinder balance – injector restricted
Post #578656 Tue Apr 09 2019 10:31am
