Home > Faults & Fixes > Charging system fault
hh
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Java Black
Hi All,
2010 3ltr v6 diesel.
Charging system fault came on dash board the car then stalled checks battery 9.3volts, charged battery overnight car started but no charge going to the battery, voltage voltage dropping slowly.
I suspect the alternator is shot and needing replaced.
Could it be anything else?
Thanks for looking
HH
Post #577837 Mon Mar 25 2019 5:56pm
gogsy1956
I would think that would be your first port of call if you have checked he voltage across the battery at tickover 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #577843 Mon Mar 25 2019 6:54pm
Brit Plumber
Have you checked all belts and connections? Had any work done recently? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577844 Mon Mar 25 2019 6:55pm
hh
Hi Gogsy1956. It was the most obvious for normal cars wasn’t sure about the sport I will get it changed asap.
Hi Brit Plumber, all belts are okay and well tensioned all connectors are tight and in place. But I like your thinking
Cheers guys
Post #577850 Mon Mar 25 2019 7:40pm
If the battery has got that low then you'll need a new battery too. 2012 SDV6 - it's missing a couple of cylinders
Post #577859 Mon Mar 25 2019 9:40pm
hh
Thanks RRSTDV8 I was hoping to get away with the battery but it makes sense to replace the battery as well.
Post #577873 Tue Mar 26 2019 10:23am
