![]() | Home > Maintenance & Modifications > Door puddle lights not working |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
have you tried flipping the bulb
dkelly Member Since: 15 Mar 2019 Location: Cardiff Posts: 9 ![]() ![]() ![]() |
Hi Mr Luke.
Are we talking about the mirror puddle lamps or the bottom of the door? 2019 5.0 SC SVA (Current)
Ok, are they replacement bulbs or projectors with a logo? If projectors they don’t last long. I bought expensive ones and they lasted 6 months. Got my money back and still have them to repair at some time. 2019 5.0 SC SVA (Current)
Just replacement bulbs, changed from the normal bulb to LED. all other internal lights are working ok just the front door bulbs |
Have you tried them else where?
Agh, not quite. My mirror lamps come on when I unlock the car and the front door ones don’t. If I start the car, turn it off and open the door, the bottom door lamps come on and not the mirror lamps. Have you got an IID tool? You may need to check and clear faults as mine record faults as untethered and then dump them after a few starts and it all works again. 2019 5.0 SC SVA (Current)
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
I suspect you have to leave a bulb in one location and hopefully the otherwise may work?
Hi Thanks, I've not got a tool but I'll see if I can get hold of one. Thank you for your time. |
Hi Andy. bulbs have been in place since I finished fault finding for over a week but still no luck with the front door lights.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Could try fuse 57 behind glove box, but I would have thought if some are working it will not be the fuse.
Here is a screen shot of the 2 fault codes I got when my front door lights failed. They are tethered so I had to clear them with the IID tool
