Home > Maintenance & Modifications > Door puddle lights not working
dkelly
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi.
I've just purchased a RRS 2010 V6, I've replaced all the internal bulbs to LED and now the front door puddle lights are not working. The bulbs are working fine. I've searched the web and I've noticed that this is a pretty common problem after replacing all internal bulds but I've found no solution to any of the issues.
Can someone help please.
Thanks
Darryl
Post #577072 Fri Mar 15 2019 1:44pm
mrluke
have you tried flipping the bulb
I am pretty sure it matters on them bulbs the correct + & - orientation.
Also when i did mine i managed to blow the fuse once , so might wanna check that also :p
Post #577076 Fri Mar 15 2019 2:11pm
dkelly
Hi Mr Luke.
Thank you for the comment.
I've double checked the bulbs an removed the whole unit and installed the unit in the book and they both work fine.
Concerning the fuse when you had the issue, is there a separate fuse for the front door puddle bulbs or are they on the same fuse as something else. All other internal lights are working as they should.
Many thanks
Regards
Darryl
Post #577078 Fri Mar 15 2019 2:17pm
Brit Plumber
Are we talking about the mirror puddle lamps or the bottom of the door? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577098 Fri Mar 15 2019 6:39pm
dkelly
The lamps in the bottom of the front doors.
Thx
Post #577109 Fri Mar 15 2019 7:40pm
Brit Plumber
Ok, are they replacement bulbs or projectors with a logo? If projectors they don’t last long. I bought expensive ones and they lasted 6 months. Got my money back and still have them to repair at some time. 2019 5.0 SC SVA (Current)
Post #577111 Fri Mar 15 2019 8:01pm
dkelly
Just replacement bulbs, changed from the normal bulb to LED. all other internal lights are working ok just the front door bulbs
Post #577112 Fri Mar 15 2019 8:06pm
Brit Plumber
Have you tried them else where?
Oh, and I found that they can take a while to work sometimes. They also only work when you exit the vehicle not on entry. 2019 5.0 SC SVA (Current)
Post #577114 Fri Mar 15 2019 8:13pm
dkelly
Bulbs and holding units are working fine, have removed them from the front doors and tried in the back doors and they work fine. Working bulbs and units moved from the back doors and replaced in the front and again they dont work.
The door lights should come on with all the other interior lights when the doors are opened.
I've noticed that this is a known problem from other forums but nobody has posted any fix to the problem.
Trying to find out if it is a fuse issue but cant find out the fuse number or other electronics using the same fuse.
Post #577115 Fri Mar 15 2019 8:19pm
Brit Plumber
Agh, not quite. My mirror lamps come on when I unlock the car and the front door ones don’t. If I start the car, turn it off and open the door, the bottom door lamps come on and not the mirror lamps. Have you got an IID tool? You may need to check and clear faults as mine record faults as untethered and then dump them after a few starts and it all works again. 2019 5.0 SC SVA (Current)
Post #577116 Fri Mar 15 2019 8:27pm
I suspect you have to leave a bulb in one location and hopefully the otherwise may work?
Do you have mirror welcome lights?
Post #577117 Fri Mar 15 2019 8:28pm
dkelly
Hi Thanks, I've not got a tool but I'll see if I can get hold of one. Thank you for your time.
Post #577118 Fri Mar 15 2019 8:31pm
dkelly
Hi Andy. bulbs have been in place since I finished fault finding for over a week but still no luck with the front door lights.
I know the bulbs are ok and polarity is correct, bulb holders are also ok. The only thing left I think is possibly the fuse.
Post #577119 Fri Mar 15 2019 8:34pm
Could try fuse 57 behind glove box, but I would have thought if some are working it will not be the fuse.
Post #577121 Fri Mar 15 2019 9:32pm
Brit Plumber
Here is a screen shot of the 2 fault codes I got when my front door lights failed. They are tethered so I had to clear them with the IID tool
Post #577132 Sat Mar 16 2019 8:19am
