Home > Maintenance & Modifications > Door puddle lights not working
Mine throws that fault up on a regular basis although there working fine, I just put it down to the fact that I have a couple of the projector lamps fitted to the front doors.
Post #577145 Sat Mar 16 2019 10:04am
dkelly
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Thank you for the info and the photos of the errors you had. Once you cleared the errors did the door puddle lights work? I've asked around over the weekend and I dont know anyone who owns an IID, can you recommend a website so I can purchase one and the price I should be paying?
Many thanks
Post #577289 Mon Mar 18 2019 10:05am
They are £425
Good tool , not sure if it will fix this.
Gap iid bt
Post #577292 Mon Mar 18 2019 10:14am
dkelly
Hi Andy, thank you for the info. I'd like to get the lights working but at £425 I think i might leave it for the moment especially if there's no guarantee that the error reset will resolve the problem.
Post #577293 Mon Mar 18 2019 10:25am
WARPYB1
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Hi everyone just did the same thing now front puddle lights don’t work in passenger or drivers but rear ones work fine ? Did anyone find a fix ?
Post #631810 Mon Mar 20 2023 7:31pm
NoExpert
Load resistors such as the ones Osram offer should work. I’m using them in my front doors with no problems. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #631812 Mon Mar 20 2023 9:42pm
Kasket
United States
Same thing happened with mine only the front bottom of the door lights wouldn't work. I just recently spliced into both front and rear fog light harnesses for a couple light bars. Blew fuse #25 (10) and replaced it with a (15) now the lights sometimes come on when i open the door while driving. Anyone solve this issue yet?
Post #632879 Fri May 05 2023 9:32am
