Home > In Car Electronics > Standard double din stereo?
Page 4 of 5 <12345>
I would think so.
As long as it ends up at the thin blue wire on the car.
Post #576086 Thu Feb 28 2019 8:48pm
M9G UK
ok thanks Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #576087 Thu Feb 28 2019 9:02pm
M9G UK
Andy K wrote:
I don't know if you intend to use the analogue radio, but if you do, make sure the ariel amplifiers are being powered up via the blue wire
So I've just had a reply from connects2 and they say the aerial they supply in the kit I have bought is a passive aerial and doesn't require power
Probably don't need to connect the blue wires then? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576113 Fri Mar 01 2019 12:47pm
What aerial do they supply? A DAB one?
The car needs a supply on the blue wire for the analogue aerial to work.
If you are using the cars aerial cable, you need to connect power the blue wire
Post #576128 Fri Mar 01 2019 4:22pm
M9G UK
Na they just provide a piece of aeriel cable with a connector at each end to link between original aerial cable and then plugs into the head unit. On the original loom the blue wire lines up with the blue on the adapter harness and when I connect that to the auto antenna blue wire from the stereo it makes no difference. Its weird I can pick up radio 1 and radio 2 crystal clear but the local radio stations it's awful as if there's no signal 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576131 Fri Mar 01 2019 4:40pm
M9G UK
Is it the blue on the larger block or the one on the smaller block? I would think the blue on the smaller block is for the Aux input? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576133 Fri Mar 01 2019 4:47pm
correct, use larger block.
maybe you need to move the car, and have a re tune
Post #576134 Fri Mar 01 2019 5:08pm
M9G UK
and the blue auto antenna cable coming from the stereo?
if so it makes no difference hmmmmm 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576135 Fri Mar 01 2019 5:10pm
if you have a test meter, you could check the blue out the headunit is 12v when switched on
Post #576136 Fri Mar 01 2019 5:24pm
M9G UK
Good shout Andy, no feed from the blue wire of the stereo, stuck the blue wire from the adapter harness onto the red Live feed and voila radio works.
all in and working, will upload pics tomorrow as its dark out there now
Cheers bud appreciate all the help you've given me Thumbs Up Thumbs Up Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576139 Fri Mar 01 2019 5:38pm
Well it’s not a switch feed on the harness so the battery will go flat.
Unless you connected a wire from the cigar lighter. You could connect that up
Post #576140 Fri Mar 01 2019 6:36pm
M9G UK
the yellow is a permanent feed and stays 12volt when ignition switched off, the red drops to zero when ignition off.
I have a few things to tweak, do you know what colour wire is for the illumination as mine doesn't light up when lights switched on and there is an illumination wire from the back of the head unit.
The adapter for the key switch 1,2 and key ground only works on the phone buttons on the steering wheel but the volume buttons don't so will need to go back to connects2 to ask them what to do as there are various coloured wires you have to leave or cut depending on model of head unit but we are getting there 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576141 Fri Mar 01 2019 7:01pm
No illumination wire on landrover connector.
Connect to cigar lighter light.
Can’t help with steering wheel buttons. Except they are the LR grey wires.
I would guess there are settings on the head unit?
Post #576144 Fri Mar 01 2019 7:49pm
M9G UK
oh yeah that's a good idea, im sure the original stereo lights up when the lights are turned on so surely that would indicate there would be a wire for illumination but doesn't matter as you say can connect to the cigarette lighter. I have tried looking through wiring diagrams but cant seem to find anything on the head unit
Yeah there are settings on the head unit to setup the steering wheel controls but the only one that is working is the phone dial button 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576146 Fri Mar 01 2019 8:07pm
Lights on and ignition on messages come across the can bus to the LR headunit.
Post #576147 Fri Mar 01 2019 8:13pm
Page 4 of 5 <12345>
