Home > In Car Electronics > Standard double din stereo?
Page 3 of 5 <12345>
Ok. Good luck Thumbs Up
Your only really paying £70 for your steering wheel buttons to work and some connectors. But it could be worse
Post #575969 Tue Feb 26 2019 7:14pm
BTW, the car connector does not have an ignition supply available, that would usually connect to the red or yellow head unit wire.
So you will probably need to run a wire from under the cigar light socket (green wire?) to the head unit.
So if it doesn't work when you plug it in, follow the red and yellow wire and you will see what I mean
Post #575971 Tue Feb 26 2019 7:22pm
M9G UK
Thanks for that, will do Thumbs Up
hopefully next post will be pics of it all installed and up and running Very Happy Very Happy Very Happy 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #575975 Tue Feb 26 2019 7:32pm
M9G UK
Ok so I had a response from InCarTec today with a list of components I will need and yes they have the ability to keep the satnav/4x4 screen still working but it means the original stereo has to still be installed but somewhere in behind the dash but will still loose audio from the satnav but can buy another really expensive cable to get the satnav audio to work. all in its going to be well over £200 just for the cables and to be honest im not keen on fitting the original stereo in behind the dash and I don't consider the satnav much good anyway.
So this is the kit for stereos' that do not have the amp and fibre optic cables but do have 2 fibre optic cables running from the stereo to the satnav/4x4 screen
Heres a list of components they sent me....
https://incartec.co.uk/Landrover/Range-Rov...le-din/154
if your car has standard audio with sat nav but no Harmon Kardon then you need
29-712
50-786
51-012
21-106
29-007 ( for Pioneer)
The old sat nav will work but you will lose the voice.. to keep voice use 10-651
I ended up buying the Connects2 CTKLR03 harness from fleabay which will run double din units but will lose satnav screen
My Xtrons double din head unit arrived today and im just waiting for the harness to arrive which should be tomorrow. My last Xtrons unit I owned was amazing and I installed IGO satnav on it and found it to be spot on and really good so I will happily use that one and not bothered about the satnav/4x4 screen being off (annoying at night anyway)
As the Xtrons unit is a universal unit when I sell the car I will just remove it and put the original back in.
I will take pics of the install and post them up.
Cheers 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576035 Wed Feb 27 2019 7:06pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Here is my setup
http://www.rrsport.co.uk/gallery/picEditor.php
see link above MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
REAR 9 INCH TOUCH SCREEN HEADREST TV SCREENS, WIRELESS HEADRESTS, IN-CAR WIFI MIRROR BOX FOR WATCHING INTERNET TVIE BBC I-PLAYER ETC... FROM ANDROID, WINDOWS AND IOS PHONES ON THE GO ON ALL SCREENS
Post #576037 Wed Feb 27 2019 7:21pm
As you say the standard nav is hopeless.
No point paying to have it working.
Post #576039 Wed Feb 27 2019 7:54pm
M9G UK
nothing there mani just a pic editor 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576040 Wed Feb 27 2019 7:55pm
M9G UK
Thumbs Up Thumbs Up Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576041 Wed Feb 27 2019 7:56pm
M9G UK
Harness arrived today and so I quickly plugged it all in to see what happens and we had Little Mix blasting out Very Happy
All seems good, just fit it all at the weekend
Will take pics so anyone in the future can see what I did 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576071 Thu Feb 28 2019 6:14pm
I think you probably need to unplug the connectors on the display above, (well the main connector with all the wires)
Otherwise just get stuck on the landrover logo doesn't it? and annoying at night.
Post #576074 Thu Feb 28 2019 6:27pm
M9G UK
Ok but thinking about it I don't think it came on when I plugged the new stereo in but maybe just didn't notice it, too dark to go and try again so will see at the weekend. I don't think it will come on without the optic cables but yeah good point and will sort that at the weekend when installing
Cheers Andy Thumbs Up
It will be sooooo good to have an android unit again Very Happy 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576076 Thu Feb 28 2019 6:32pm
I don't know if you intend to use the analogue radio, but if you do, make sure the ariel amplifiers are being powered up via the blue wire
Post #576079 Thu Feb 28 2019 6:58pm
M9G UK
OK, yeah will be, from experience the DAB+ is almost none existant around here.
Do you know which wires are the ariel amplifiers? Are they on the main big connector that plugs into the stereo or the smaller one that I can't plug in anywhere?
Smile
Post #576081 Thu Feb 28 2019 7:40pm
The big one.
Blue on the car and adaptor I think
Post #576083 Thu Feb 28 2019 8:12pm
M9G UK
right, yeah I got the usual blue auto ant wire on the adapter from Connects2 that is floating and I have a blue wire on the connector for the Xtrons units which has Back-car on the label which is also floating, you think these need to be connected?
Regards 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576084 Thu Feb 28 2019 8:20pm
Page 3 of 5 <12345>
