![]() | Home > General > Water in fuel |
under the car.
New filter housing required |
Filter housing or sensor?
As DM says filter housing,,ive just had a 2012 sdv6 in with same message & I changed filter & it was still same,,i message DM & he told me to change filter housing which I did & it solved the problem. Andy.
So what is the logic - the sensor screws into the actual filter so is remote from the filter housing - so how does needing a new filter housing set the sensor off? 07MY RRS TDV6
No idea Garry,,but when I changed the filter housing it got rid of the message.I was just going on what DM told me,,he has worked on enough of these,if he says its filter housing then its filter housing.Even when I drained the filter no water came out just fuel but I changed the filter anyway. Andy.
Andy - not disputing the result just trying to understand why - the only thing that I can think of is that the filter not sealing on the housing can let water in which sets off the water alarm but then fuel would also be squirting out. 07MY RRS TDV6
Water sensor is also part of the filter housing...
so its a faulty sensor ?
Faulty housing giving a false alarm. Never seen actual water in fuel on a 2.7/3.0 yet |
Sorry Disco Mikey your comments are confusing.
The fuel filter housing has a sensor wire integrated into the plastic, which makes contact with the top of the filter, and is bolted to the chassis
Ok follow you now - the sensor completes its circuit through the filter housing when water is present - but if there is a fault in the housing side it may give the "water in fuel" indication.
I had this problem on mine. As Mikey says, it is related to fuel filter housing. I replaced mine and it solved the problem.
