Home > General > Water in fuel
ratty2828
England 2007 Range Rover Sport TDV8 HSE Java Black
Water in fuel
Hello
Need some advice.getting water in fuel warning whats the best way to deal with this Thanks in advance
Post #574661 Wed Feb 06 2019 10:40am
under the car.
approx. in the area under the drivers seat is the fuel filter.
You need to loosen the wheel on the bottom a couple of turns and let the water out. Once the water has come out, fuel will start coming out, so turn it off then.
I guess if you drain it into a bowl it should be obvious when fuel starts coming out as it will look oily
Post #574668 Wed Feb 06 2019 12:03pm
Disco_Mikey
New filter housing required Thumbs Up
Post #574701 Wed Feb 06 2019 6:52pm
garrycol
Australia
Filter housing or sensor?
If a filter housing wouldn't there be a leak? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #574711 Thu Feb 07 2019 12:25am
Tyrefitter
As DM says filter housing,,ive just had a 2012 sdv6 in with same message & I changed filter & it was still same,,i message DM & he told me to change filter housing which I did & it solved the problem. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #574720 Thu Feb 07 2019 7:48am
garrycol
Australia
So what is the logic - the sensor screws into the actual filter so is remote from the filter housing - so how does needing a new filter housing set the sensor off? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #574723 Thu Feb 07 2019 8:01am
Tyrefitter
No idea Garry,,but when I changed the filter housing it got rid of the message.I was just going on what DM told me,,he has worked on enough of these,if he says its filter housing then its filter housing.Even when I drained the filter no water came out just fuel but I changed the filter anyway. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #574726 Thu Feb 07 2019 8:54am
garrycol
Australia
Andy - not disputing the result just trying to understand why - the only thing that I can think of is that the filter not sealing on the housing can let water in which sets off the water alarm but then fuel would also be squirting out. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #574729 Thu Feb 07 2019 10:18am
Disco_Mikey
Water sensor is also part of the filter housing...
Nothing to do with water being in the fuel Thumbs Up
Post #574774 Thu Feb 07 2019 5:56pm
so its a faulty sensor ?
false alarm ?
Post #574777 Thu Feb 07 2019 6:34pm
Disco_Mikey
Faulty housing giving a false alarm. Never seen actual water in fuel on a 2.7/3.0 yet
Post #574781 Thu Feb 07 2019 7:29pm
garrycol
Australia
Sorry Disco Mikey your comments are confusing.
The filter housing is what is bolted to the chassis and has the inlet and outlet fuel pipes and the filter twists into it.
At the bottom of the filter you have the sensor that screws onto the filter, if screwed in too tight the sensor housing can crack causing leaks and false indications.
So are you talking about the fuel filter housing that bolts to the chassis or the sensor housing that bolts up to the bottom fuel filter.
Oh - I dont know about the UK, but here it is cheaper to buy the complete fuel filter kit that comes with fuel filter housing, fuel filter and sensor than just the sensor by itself.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #574798 Fri Feb 08 2019 12:02am
Disco_Mikey
The fuel filter housing has a sensor wire integrated into the plastic, which makes contact with the top of the filter, and is bolted to the chassis
The sensor and drain that screw into the bottom of the filter are exactly that, a sensor and drain...
If it displays a "Water in Fuel" warning, and the fuel is clear of water it needs a new fuel filter housing
So, it needs a fuel filter housing to clear the warning
Post #574801 Fri Feb 08 2019 6:39am
garrycol
Australia
Ok follow you now - the sensor completes its circuit through the filter housing when water is present - but if there is a fault in the housing side it may give the "water in fuel" indication.
Not trying to be difficult but trying to understand the system a bit better.
Thanks for clarifying Smile
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #574804 Fri Feb 08 2019 8:35am
knwatkins
I had this problem on mine. As Mikey says, it is related to fuel filter housing. I replaced mine and it solved the problem.
It's a bit of a pig of a job if you have fat fingers but doable without dropping the subframe. Kev
Post #574962 Sun Feb 10 2019 5:24pm
