Home > Technical > ATC (automatic temperature control) module Help!!
Page 2 of 3 <123>
arh you should have got the supercharged engine !
Post #574303 Sat Feb 02 2019 10:54am
Ziguk
England 2005 Range Rover Sport 4.4 V8 HSE Java Black
Yeh would have been nice I’m only getting 16mpg as it is Laughing
Post #574304 Sat Feb 02 2019 10:56am
I think the SC does 13 MPG.
People say the MPG is similar but maybe it isn't!
Post #574305 Sat Feb 02 2019 11:19am
Ziguk
Have to tow a fuel tanker lol, I did get price to covert to lpg, £1600 + vat for brc system.
Had a cayenne v8 on lpg was very good to be fair
Post #574306 Sat Feb 02 2019 11:26am
Ziguk
Update
Rear screen demister now working
Took spoiler off, 3 nuts 2 torx
Disconnected all connectors give them a good clean there were no breaks
Put it all back, now working.
Checked for broken wires in passenger sill to try to fix the electric mirrors and electric drivers seat but didn’t find and all wiring looks good tbh so don’t know what is causing this
Windscreen washer both front and rear still not working, did notice the relay no was jammed into socket got it out lots of green corrosion on tabs cleaned this but still not working 😔
Post #574402 Sun Feb 03 2019 11:49am
The water relay is soldered into the rear of the glovebox fusebox. When you request water, can, you hear it click?
If you can hear clicking when pressing water buttons on off quickly, both front and rear then you need to:
There are 2 relays, so unlikely both have failed
1) Check absolutely fuse 11 behind the glovebox has power on both sides.
Post #574403 Sun Feb 03 2019 11:56am
Ziguk
Hi
Can’t hear no clicks or pump even trying how do you get to the rear of the fuse box?
Checked fuses numerous times with a meter and replaced any fuse that may have any relation to water pump and seats
All still same
Post #574404 Sun Feb 03 2019 12:02pm
there are 2 relays front / rear so I'm sure one must be clicking ? (BEHIND GLOVEBOX)
You don't get to the rear of the fuse box, don't even think about it !
check fuse 11 has power on both sides (with ignition I on)
Post #574406 Sun Feb 03 2019 12:07pm
Ziguk
Thanks Will check for voltage, there are 2 pumps On water bottle one for lights this works the other I presume does both front and rear washers I presume I haven’t really looked at back to see if there’s another water bottle tbh
Post #574408 Sun Feb 03 2019 12:17pm
when pressing both front and rear water quickly you must be able to hear one relay clicking.
I can't believe both have failed.
CHeck the fuse has power both sides. If this is good and you hear clicking :
Then you need to get the pump connector in your hand. Get a test lamp or volt meter. Put one lead onto the battery + terminal. With the other lead probe/test the pump connector pins. At rest, both pump connector wires should make the light lamp / 12v as they should have a good path to earth.
If one wire does not have a connection then :
either
A That wire is broken
B A faulty relay contact (unlikely)
If you wish, you can move your lead from the battery + terminal to ground.
Probe the conenctor wires again. When the front wash button is pressed, one wire should light,
when the rear wash is pressed the other wire should goto 12v / light
Let me know the results.
Are you using this car, and need to get the front wash working? or no hurry?
Post #574409 Sun Feb 03 2019 12:23pm
that is correct. No water bottle/pump at rear
Post #574410 Sun Feb 03 2019 12:26pm
Ziguk
Thanks
At the moment it’s my daily just bought approx 2 weeks ago so ideally need this issue sorted asap
Post #574416 Sun Feb 03 2019 1:33pm
Ziguk
Thanks 👍👍
Washer front and rear now working 😁
It did turn out to be fuse, I tested continuity and my meter beeped so presumed it was working, I did what you said and checked voltage both sides, one side did show voltage the other didn’t so I replaced andhey presto all working.
Don’t know what the falsereading was about....
Just the drivers electric seat, heated seat and mirrors to. Fix they are linked via memory module, I had a relay clicking like mad from under seat, even with ignition off I disconnected a large white connector to stop this draining battery in case it was a short.
Checked splices on passenger side but nothing obvious tbh, it maybe that the memory module is Censored the are only about £80 new at the moment if I need replacement.
Thanks for your help 😃
Post #574443 Sun Feb 03 2019 7:58pm
So what works and what doesn’t with seat and mirror MoVement ?
Post #574444 Sun Feb 03 2019 8:04pm
Ziguk
Hi
Nothing at all
Both mirrors and seat movement were working then lately now and again when driving along I’d feel the odd movement from seat out of nowhere then I realised that I’d could not adjust seat and could not adjust mirrors.
The mirrors do fold in and out.
I started to get rapid clicking from under seat sounded like a relay, I think it’s coming from the memory module under seat to stop it from clicking I disconnected large white connector.
The heated driver seat has never worked whilst I’ve owned car and it’s the least important tbh.
Today I checked all the fuses and there is power to both sides of each fuse.
There are approx 4 fuses in glovebox area which have seat and direction arrows one also has mirror on it
The seat heating fuses are in engine area and these also have voltage both side when seat heating button is on
Thanks
Post #574462 Sun Feb 03 2019 9:21pm
Page 2 of 3 <123>
