![]() | Home > Technical > ATC (automatic temperature control) module Help!! |
arh you should have got the supercharged engine ! |
Ziguk Member Since: 01 Feb 2019 Location: Wrexham Posts: 19 ![]() ![]() ![]() |
Yeh would have been nice I’m only getting 16mpg as it is |
I think the SC does 13 MPG.
Update
The water relay is soldered into the rear of the glovebox fusebox. When you request water, can, you hear it click?
Hi
there are 2 relays front / rear so I'm sure one must be clicking ? (BEHIND GLOVEBOX)
Thanks Will check for voltage, there are 2 pumps On water bottle one for lights this works the other I presume does both front and rear washers I presume I haven’t really looked at back to see if there’s another water bottle tbh |
when pressing both front and rear water quickly you must be able to hear one relay clicking.
that is correct. No water bottle/pump at rear |
Thanks
Thanks 👍👍
So what works and what doesn’t with seat and mirror MoVement ? |
Hi
