Home > Technical > ATC (automatic temperature control) module Help!! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
arh you should have got the supercharged engine ! |
Sat Feb 02 2019 10:54am |
Ziguk Member Since: 01 Feb 2019 Location: Wrexham Posts: 19 |
Yeh would have been nice I’m only getting 16mpg as it is |
Sat Feb 02 2019 10:56am |
I think the SC does 13 MPG.
Sat Feb 02 2019 11:19am |
Update
Sun Feb 03 2019 11:49am |
The water relay is soldered into the rear of the glovebox fusebox. When you request water, can, you hear it click?
Sun Feb 03 2019 11:56am |
Hi
Sun Feb 03 2019 12:02pm |
there are 2 relays front / rear so I'm sure one must be clicking ? (BEHIND GLOVEBOX)
Sun Feb 03 2019 12:07pm |
Thanks Will check for voltage, there are 2 pumps On water bottle one for lights this works the other I presume does both front and rear washers I presume I haven’t really looked at back to see if there’s another water bottle tbh |
Sun Feb 03 2019 12:17pm |
when pressing both front and rear water quickly you must be able to hear one relay clicking.
Sun Feb 03 2019 12:23pm |
that is correct. No water bottle/pump at rear |
Sun Feb 03 2019 12:26pm |
Thanks
Sun Feb 03 2019 1:33pm |
Thanks 👍👍
Sun Feb 03 2019 7:58pm |
So what works and what doesn’t with seat and mirror MoVement ? |
Sun Feb 03 2019 8:04pm |
Hi
Sun Feb 03 2019 9:21pm |
