Home > General (L494) > Battery charging location |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
If you have the tow pack there is a link on two of the pins on the tow electrical socket.
Fri Jan 18 2019 10:43pm |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
We haven’t got the electric tow bar so I’m assuming we haven’t got the tow pack 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
Fri Jan 18 2019 10:59pm |
No I am referring to the standard fixed towbar and LR electrical socket.
Fri Jan 18 2019 11:04pm |
Yes under the bonnet is fine, so there are connection points under the bonnet? 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
Fri Jan 18 2019 11:14pm |
Yes, have a look in your handbook, I presumed that you had looked at the recommended connections under the bonnet.
Fri Jan 18 2019 11:57pm |
I posted a ‘how to connect up a solar trickle charger’ thread in 2016 if you search you will find it and it has photos showing how to connect and how to thread the cables so they are hidden and you can leave the solar panel on top of the dash.
Sat Jan 19 2019 1:55am |
Thanks mate 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
Sat Jan 19 2019 8:36am |
Another lazy question - is it a ‘sealed’ or ‘standard’ battery? 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
Sat Jan 19 2019 12:00pm |
J2D its sealed and under the spare wheel but if you have the seven seater its in the same place (but from memory) no spare wheel in the 7 seater. You will have a second small battery behind the side cover rear right in the cargo compartment to support the crazy auto restart system. Hope this helps.
Sat Jan 19 2019 6:42pm |
