Home > General (L494) > Battery charging location
J2D
Haven’t had our RRS long, and wanted to top the battery up, Where do you guys connect the your chargers?
John 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁
Post #573382 Fri Jan 18 2019 6:49pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
If you have the tow pack there is a link on two of the pins on the tow electrical socket.
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #573395 Fri Jan 18 2019 10:43pm
J2D
We haven’t got the electric tow bar so I’m assuming we haven’t got the tow pack 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁
Post #573397 Fri Jan 18 2019 10:59pm
Barryp
No I am referring to the standard fixed towbar and LR electrical socket.
Plenty of other options regarding how to do it on here if you do a search.
I am assuming that you don't want to use the standard fit under bonnet battery connections?
Regards
Post #573398 Fri Jan 18 2019 11:04pm
J2D
Yes under the bonnet is fine, so there are connection points under the bonnet? 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁
Post #573400 Fri Jan 18 2019 11:14pm
Barryp
Yes, have a look in your handbook, I presumed that you had looked at the recommended connections under the bonnet.
Most queries on here are to find a connection point that doesn't require the bonnet to be opened.
Regards
Post #573407 Fri Jan 18 2019 11:57pm
Tim in Scotland
I posted a ‘how to connect up a solar trickle charger’ thread in 2016 if you search you will find it and it has photos showing how to connect and how to thread the cables so they are hidden and you can leave the solar panel on top of the dash.
No need to search it’s here http://www.rrsport.co.uk/forum/topic49141.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #573412 Sat Jan 19 2019 1:55am
J2D
Thanks mate 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁
Post #573418 Sat Jan 19 2019 8:36am
J2D
Another lazy question - is it a ‘sealed’ or ‘standard’ battery? 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁
Post #573427 Sat Jan 19 2019 12:00pm
Barryp
J2D its sealed and under the spare wheel but if you have the seven seater its in the same place (but from memory) no spare wheel in the 7 seater. You will have a second small battery behind the side cover rear right in the cargo compartment to support the crazy auto restart system. Hope this helps.
Regards
Post #573456 Sat Jan 19 2019 6:42pm
