![]() | Home > General (L494) > Oil dilution is our fault apparently! |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
Well I have some news. Turns out DPF is fine. Issue was oil leaking to the turbo actuator which in turn was causing electrical faults that may not relate to the issue.The fix is a new pipe with a drain so oil cannot enter the actuator.Bad news is this pipe isn't in stock anywhere and my car may be off the road for months? The tech was great in getting back and telling me what the issue was he felt bad re the parts but said they must replace as per LR specs so all parts must be in before they start. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
A friend of mine with an Evoque has just had his DPF replaced.
Antmac Member Since: 15 Jan 2019 Location: Kent Posts: 3 ![]() |
I have a 65 plate 3.0 sdv6 hse.
Dogboy Member Since: 07 Oct 2017 Location: Essex Posts: 35 ![]() ![]() |
Of course they say it didn't. They only put regular service's onto their system as doing otherwise would leave an audit trail and an admission there is a design fault with the engine. |
Ask for an oil test. every 6,000 miles would be a good time to change most vehicles are 10,000 miles change anyway, so this could be a great way to give you long engine life. I aim to change mine every 12,000 k's so not much difference. All diesels no matter what brand with DFP suffer similar dilution. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
CRC@LandRover Member Since: 20 Jul 2012 Location: Coventry, West Midlands Posts: 213 ![]() ![]() |
Hi Antmac,
Please note although Land Rover will try to assist you with your issue, we are unable to provide any technical advice. This account is available between 0900 and 17:00 hours Monday Friday. Outside of this time if you require assistance, please drop us a Private Message and we'll get back to you. |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
Visited Stratstone Aylesbury yesterday... hadn’t been back since sept 2018... noticed significant improvements from an interaction perspective.... new service manager seems to be making good progress.
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
Does this mean that the “fix” has simply relaxed the criteria for an oil dilution related oil change? ie increased the risk? |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Did they check for oil dilution?
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Remember that oil dilution percentage is just a calculation, it could be much higher or much lower.
I was told the oil was fine - was initially changed at a service prior to collection in May 2018, then oil and filter changed in Sept 2018 as part of the fix...didn’t get more detail around what was done yesterday - even when asked. MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
A quick update.
So mine went from service now to 10k Miles... looks like it takes them a few attempts before they can fix it. Keep us posted and I’ll monitor mine too MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Just read this announcement from Toyota Australia who have also had DPF and oil dilution issues.
