Home > General > Identify cable ?
micknolan
Identify cable ?
Trying to identify cable ?
Came to change bushes the other day noticed cable on passenger side wheel just hanging there.
Had wheel bearing changed by Land Rover passenger side other month, was thinking have they just left it off ?
Had a look other side, can’t see the same cable running down
Thanks
Post #572743 Thu Jan 10 2019 9:21am
micknolan
Post #572744 Thu Jan 10 2019 9:23am
Looks like could be brake pad wear sensor wire to me.
Post #572745 Thu Jan 10 2019 9:32am
blueanchorinn
Brake pad sensor. The lumpy bit should be in the pad. Only fitted one side and diagonally opposite on the rear
Post #572749 Thu Jan 10 2019 9:56am
micknolan
Thank you
Can’t see why they left it off ☹️
Post #572751 Thu Jan 10 2019 10:11am
Tyrefitter
Ive sometimes knocked the rear one off when cleaning the inner barrels on the wheels,,just pushes back onto the pad. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #572752 Thu Jan 10 2019 11:37am
Brit Plumber
Mine drop out on its own occasionally, it’s been removed for a few jobs and I think it’s just got worn. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572775 Thu Jan 10 2019 3:49pm
Should be a small spring clip on end of sensor to help retain it in the pad, may have got lost if previously removed.
Post #572789 Thu Jan 10 2019 8:16pm
Brit Plumber
I’m definitely missing that bit. Probably need a new cable. 2019 5.0 SC SVA (Current)
Post #572792 Thu Jan 10 2019 8:31pm
micknolan wrote:
Thank you
Was work done by a LR dealership? That'd be why! Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #572841 Fri Jan 11 2019 4:10pm
micknolan
Yes , can’t see what I’m paying for, don’t seem like there work warrants paying that amount.
Unless selling car, maybe looks good that you have used dealership for service and work in service book. I can not see why most of us use them.
Maybe a recamendation on idepentant in my area, Birmingham.
Thanks
Post #572847 Fri Jan 11 2019 5:16pm
Just goes to prove a Full Dealer Service History isn't as good as it's cracked up to be, all down to the individual doing the work and his ethics.
Post #572875 Fri Jan 11 2019 8:41pm
micknolan
I felt like like it was a Saturday and they wanted to sod off by 1
Even tho I was paying 1500 plus for belt change etc.
Post #572879 Fri Jan 11 2019 8:48pm
Unfortunately that would appear to be most L/R dealers attitude to their customer's.
Post #572881 Fri Jan 11 2019 8:51pm
