![]() | Home > Technical > Retrofit Power Liftgate |
Do you mean the power tail gate of the 2012MY where the whole tail gate lifts in one piece? 2019 5.0 SC SVA (Current)
kuck0r Member Since: 15 Aug 2018 Location: Linz Posts: 5 ![]() ![]() ![]() |
Yes, I mean the power tailgate. I don't exactly know in which MYs it was available, but I thought it came with the 2010 facelift... |
The power tail gate is the 2012MY, you would need a whole new tail gate with the 2 lifters/actuators.
I wouldn't bother. The old split hatch was more useful and more reliable. Press the button and lift. The power tail has a habit of not working properly. Half the time these days I press the button, it unlatches and then I lift it manually - which is hard work as the motors add drag. 2012 SDV6 - it's missing a couple of cylinders
Thank you for your detailed explanation. I was not aware of the fact, that only the MY2012 has the power tailgate.
A split tailgate is also heaver, so more difficult to power open |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
My recollection is that the MY12 one piece tailgate is aluminium so therefore much lighter. I am guessing that the MY12 struts and electric motor may struggle to lift the original two piece steel tailgate. Current: 2020 P400e HSE Dynamic
My 2005 two piece is aluminum (thankfully!) |
Horses for courses. Have never had any tailgate probs on my 2012 over 3.5 yrs and 60k miles. Probably famous last words |
Johnywee Member Since: 07 Nov 2018 Location: Glasgow Posts: 8 ![]() ![]() ![]() |
I just fitted an aftermarket kit to my 2011 RR sport, works perfectly off both remote and button, fitted in a couple of hours.
So are you saying you fitted a aftermarket kit to convert the two piece tailgate to powerlift operation? I think there may be a few people interested in that if you care to post a link to the supplier.
Hi Col
johnrambo Member Since: 30 Jan 2019 Location: scotland Posts: 27 ![]() ![]() ![]() |
whats the cost of this kit |
around 500 pounds with 3 year warranty |
