![]() | Home > General > Dash Cam |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
If you can see through it, it can see through it. RRS MY17 SDV6 AB
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
image is just like looking out the windows
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
Thanks Guys,
APTAL Member Since: 04 Dec 2016 Location: East Yorkshire Posts: 8 ![]() ![]() |
yes I have the BlackVue with privacy glass and its fine. |
Hi Aptal
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
DR650GW-2CH
XIII Member Since: 11 Apr 2016 Location: Radlett Posts: 37 ![]() ![]() ![]() |
The closer it is to the glass the less likely it is to pick up glare so should see through even tinited glass |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I have a Thinkware F700 no problem with factory privacy glass, hardwired in, camera has the battery voltage settings function built in to it, also fitted with 128gb memory card.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Mini 0906 . Rear works fine with tinted |
Yes, I have front and rear cam hardwired and image out of rear is not affected by tint. |
Thank you all for your replies..
I think there is a guide on here to show you how to fit one, it's really not that hard at all. Feel free to give me a shout if you decide to fit it yourself. |
The rear looks rather fiddly to get an "invisible" installation.
Begs the question, does the camera have to be mounted on the rear window, I hate seeing bits of cable on show.
