Home > General > Dash Cam
Page 2 of 3 <123>
This is how I installed mine which I didn't think was to bad.
Post #571657 Mon Dec 24 2018 10:56am
Tyrefitter
SRE wrote:
Also look at Thinkware, they have Speed Camera Warnings built in.
Yes that’s true but with the screen in the RRS2 mine sometimes take about 2 hours before the gps connects,it usually connects when I’m pulling back onto the drive after I’ve been out for a drive. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #571658 Mon Dec 24 2018 11:06am
Autobiography1969
Thank you all for your advice and thoughts,
I am sticking with the one I said as I have taken almost 6 months deciding,
the only thing that was unsure was the rear cameras efficiency with the tint,
I will be sure to make sure whoever fits it does the best job possible to cover
the wires and to give as close to factory look, as I intend to keep the car for many
years yet..
I will give them this as an example of how I would like it to look...
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #571664 Mon Dec 24 2018 1:53pm
If you fit a Blackvue the lead has a right angle plug on the end which show even less cable, mine is a Thinkware which unfortunatly has a straight plug.
Post #571679 Mon Dec 24 2018 7:52pm
Eaters
Another thought. The RRS is notorious for dirt on the rear screen. So if you mount it outside the sweep of the wiper you will reduce its effectiveness because of dirt on the screen. Also if you mount it high it you notice it a lot every time you look in the rear view mirror. I found it seemed to be right where I wanted to see distance behind me. I’ve just moved mine to the lower part of the screen beside the wiper but within the sweep of the blade. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #571685 Mon Dec 24 2018 8:34pm
Ratkat
I have a Thinkware F800 pro hardwired front and back. I also have the factory tinted windows with an additional tint to make them darker and the images from the rear camera are perfect.
The rear camera is mounted at the bottom of the rear screen so it is just inside the wiper sweep, mounting at the top would have had to be quite far down the window to avoid the dirt. A small hole and a very short bit of cable visable but you would not notice at all.
The front camera is mounted on the passenger side so not entirely central but less obstructive to the driver’s vision, again the image is great and still covers the entire front of the car.
 MY19 RRS Autobiography Dynamic 3.0 sdv6, Carpathian Grey, black pan roof, black pack, black 22’s, black side steps, ebony/ebony interior
2019 Westfield FW Special Edition, fully loaded 180bhp
MY18 Volvo XC90 T8 Twin Engine R-Design Pro, fully loaded, Polestar (404 Bhp) - GONE
MY16 RRS Autobiography Dynamic, Firenze red, black pan roof, satin black 507's with satin black stealth pack, ebony and ivory interior. GONE
Post #571686 Mon Dec 24 2018 9:14pm
Autobiography1969
Hi looks a very nice install,
how is it connected to the screen?
I would have put it a little higher so only the actual
lens is visible , but the back looks very neat..
I also notice yours is a RRS2 mine is a RRS1 so I guess
there will be subtle install differences between the two.. ===========================================
Post #571687 Mon Dec 24 2018 9:30pm
I actualy had a F800 pro fitted but as not possible to get a nice clean tidy install due to positioning and design of plugs on front camera I took it back out and refitted my F770, now it's laid in cupboard collecting dust.
Post #571688 Mon Dec 24 2018 9:31pm
Ratkat
It is a 3M pad supplied with the kit, I thought about positioning it higher but thought the dot matrix around the black may have stopped it sticking well.
The sticky pad has settled now so the air bubble on the picture has gone.
The cables are just micro usb so you could easily buy alternate cables with right angles of you wanted to. MY19 RRS Autobiography Dynamic 3.0 sdv6, Carpathian Grey, black pan roof, black pack, black 22’s, black side steps, ebony/ebony interior
Post #571690 Mon Dec 24 2018 9:44pm
Autobiography1969
Thanks all this is great information,
RatKat,
Please don't take my comment the wrong way, it all looks very nice,
just would have done it slightly different myself..
JMHO ===========================================
Post #571692 Mon Dec 24 2018 9:55pm
Ratkat
No offence taken chap MY19 RRS Autobiography Dynamic 3.0 sdv6, Carpathian Grey, black pan roof, black pack, black 22’s, black side steps, ebony/ebony interior
Post #571696 Mon Dec 24 2018 10:03pm
Tried that, still didn't work as the sockets on camera still to close together and the plugs foul each other so cannot fit them in correctly due to the size of the moulding on the plug. If they had kept the cable entry from the top same as F770 would have been a lot better, ideal if they made a version for r/h/d vehicles as well.
F770 camera fitted, not quite as visually attractive in appearance as the F800, all a matter of personal preference I guess, but able to make a lot tidier install on the F770 in my own personal opinion.
Post #571697 Mon Dec 24 2018 10:13pm
SRE
Spain
Put it on the For Sale section. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #571707 Tue Dec 25 2018 9:24am
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
I've got the Blackvue 650 2 channel. Fitted it myself. Others seem to have gotten the cable hidden better for the rear camera. For my L494 i was informed that it is tricky to get cable completely hidden.
I wouldn't be far off saying that installation was very easy and tool used most was a loyalty type credit card - perfect for putting cable behind trim.
Don't seem to be able to access photo's that i've previously uploaded. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #571967 Sun Dec 30 2018 9:12am
HughN
Wales
One advantage of not having tinted glass is that tailgating drivers tend to drop back when they spot the camera: I might add an amber flashing LED to mine. Wink
Post #571968 Sun Dec 30 2018 10:25am
Page 2 of 3 <123>
