Home > Maintenance & Modifications > Upgraded Steering Wheel
RRSHST
United Kingdom 2006 Range Rover Sport Supercharged HST Zermatt Silver
Finally got round to installing the heated steering wheel along with paddle shift and ACC took me a while to sort out what i needed but it’s all in and working. Has anyone else done this to a 2006?
Post #568435 Tue Nov 06 2018 10:40pm
Discovery guys do.
What was needed for paddle shift?
Post #568438 Tue Nov 06 2018 11:47pm
Did my old 09 plate a few years back, only downside was then not possible to get paddle shift to work in sports mode unless there's a updated circuit board now. Plus side was mine already had the heated steering wheel wiring in the column so that bit was just basically plug and play.
Post #568441 Wed Nov 07 2018 1:06am
RRSHST
Yes the circuit board now works in sports mode I also have fitted a heating steering wheel and ACC all working great
Post #568444 Wed Nov 07 2018 8:11am
RRSHST
Andy K wrote:
Discovery guys do.
I have put all the links to what I used and the instructions on the YouTube video if that helps?
Post #568445 Wed Nov 07 2018 8:12am
geoffsnook
Had mine fitted for 18 months and previously fitted to my disco one of the best mods to date Thumbs Up
Post #568555 Thu Nov 08 2018 7:40pm
Beemer5
Hi, this looks like a great mod, I have a 3.6 tdv8, it’s got ACC, can the disco3 steering wheel be fitted and what is needed, I’ve done a couple of searches but there seems to be varying thoughts, and help Will be appreciated. I have attached one that id like to fit
Post #570747 Sun Dec 09 2018 10:18am
geoffsnook
Yes i believe it can you will need a set of boards from bbspy on here i think to make them work but that's about it Thumbs Up
Post #570758 Sun Dec 09 2018 1:51pm
TubaPlayer
How difficult was the ACC? What bits did you need? 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #570768 Sun Dec 09 2018 5:31pm
geoffsnook
Not at all difficult you just buy the add on for it from them as well
Post #570772 Sun Dec 09 2018 6:05pm
I think there is a little more involved than changing the circuit boards to retro fit ACC to a facelift variant, the radar unit or whatever they call it to start with.
Post #570795 Sun Dec 09 2018 9:19pm
TubaPlayer
Thats what i'm trying to find out, what bits i'd need 2016 Black SDV8 Autobiography
Post #570796 Sun Dec 09 2018 9:26pm
Here is some parts to be going on with, how much of it is the same as those parts already fitted to a vehicle without ACC which would just need activating I wouldn't have a clue, assuming the wiring is already there as well.
Adaptive Speed Control.
The adaptive speed control system comprises the following components:
Adaptive speed control radar module
Steering wheel control switches
ECM
Throttle intake manifold - Electric throttle
ABS module and pump
Adaptive speed control warning indicator (in the instrument cluster).
Post #570800 Sun Dec 09 2018 9:59pm
geoffsnook
Sorry as it was a Tdv8 it would have it fitted and you were trying to have your new wheel adapted did not realise it was not fitted to your car
Post #570808 Sun Dec 09 2018 11:37pm
geoffsnook
Does the op not already have ACC fitted it looks like he said it is all ready fitted so then it would only be the boards to fit as that is what i did with mine when i took my heated wheel from my Disco3 and put it on my sport Thumbs Up
Post #570816 Mon Dec 10 2018 8:56am
