![]() | Home > Maintenance & Modifications > Upgraded Steering Wheel |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Discovery guys do.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Did my old 09 plate a few years back, only downside was then not possible to get paddle shift to work in sports mode unless there's a updated circuit board now. Plus side was mine already had the heated steering wheel wiring in the column so that bit was just basically plug and play.
RRSHST Member Since: 28 Oct 2018 Location: Tottington,Bury Posts: 5 ![]() ![]() ![]() |
Yes the circuit board now works in sports mode I also have fitted a heating steering wheel and ACC all working great |
I have put all the links to what I used and the instructions on the YouTube video if that helps? |
Had mine fitted for 18 months and previously fitted to my disco one of the best mods to date |
Beemer5 Member Since: 05 Sep 2018 Location: Penyffordd Posts: 33 ![]() ![]() ![]() |
Hi, this looks like a great mod, I have a 3.6 tdv8, it’s got ACC, can the disco3 steering wheel be fitted and what is needed, I’ve done a couple of searches but there seems to be varying thoughts, and help Will be appreciated. I have attached one that id like to fit
Yes i believe it can you will need a set of boards from bbspy on here i think to make them work but that's about it |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
How difficult was the ACC? What bits did you need? 2016 Black SDV8 Autobiography
Not at all difficult you just buy the add on for it from them as well |
I think there is a little more involved than changing the circuit boards to retro fit ACC to a facelift variant, the radar unit or whatever they call it to start with. Cheers Col |
Thats what i'm trying to find out, what bits i'd need 2016 Black SDV8 Autobiography
Here is some parts to be going on with, how much of it is the same as those parts already fitted to a vehicle without ACC which would just need activating I wouldn't have a clue, assuming the wiring is already there as well.
Sorry as it was a Tdv8 it would have it fitted and you were trying to have your new wheel adapted did not realise it was not fitted to your car |
Does the op not already have ACC fitted it looks like he said it is all ready fitted so then it would only be the boards to fit as that is what i did with mine when i took my heated wheel from my Disco3 and put it on my sport |
