Home > General > 2011 tdv6 won't start trying to crank and dies.
Page 2 of 3 <123>
Brit Plumber
Cranking, ie turning the crank. The starter turns the car engine over so the engine is spinning but won’t start. If you try and start the engine but it just clicks, grinds, but doesn’t spin, it’s not cranking. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567438 Mon Oct 22 2018 12:23pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
You'll pay way more than 3k for an engine supplied and fitted. Really hope it isn't that. 2 new turbos supplied and fitted was near 4k at an indy specialist, never mind main dealer.
Post #567482 Mon Oct 22 2018 10:44pm
newlove2003
Hiya the video is here any help would be great also just cleared all the faults and the diesel a control, code P0627
Post #567741 Sat Oct 27 2018 1:53pm
Brit Plumber
Fuel pump issue, at least it not the crank.
Can you get it onto a Land Rover diagnostic tool? The IID BT tool is good.
Take a look at the fuel pump relay. 2019 5.0 SC SVA (Current)
Post #567749 Sat Oct 27 2018 2:36pm
Disco_Mikey
Agreed, its a fuelling issue.
Either lack of fuel, or lack of air. Try removing the top intercooler hose, to rule out a restriction in the inlet side
Otherwise, its potentially a fuel supply issue, or HPFP issue...
Post #567750 Sat Oct 27 2018 2:49pm
newlove2003
Thanks for the speedy reply, feel like a ton as been lifted off of me, independent range rover speacialst scared the living Censored out of me saying new engines etc, how could they miss this issue. Got a freind coming up tomorrow who is a mechanic at Merc, the car as not been serviced for quite a bit and he said he will start with that. Any pointers what he should start with first and then what ever next thank you
Post #567754 Sat Oct 27 2018 3:36pm
Brit Plumber
If it’s not been serviced in a long time, download the check sheet from topix (there maybe a copy on the site in someone’s profile) and ask him to perform all the checks and fluid changes. Also ask him to check the fuel pump relay and if he can, check for fuel pressure from the pump. I suspect you may need a new pump and relay. 2019 5.0 SC SVA (Current)
Post #567755 Sat Oct 27 2018 4:07pm
newlove2003
Will do thank you, well my mate couldn't make it he had to do somthing with his bird, so I've had a little look and seen 2 videos on changing the fuel filter doesn't look hard at all, looks very simple would to be possible that I could do this myself? Also could it be possible the reason it ain't working is down to the wiring on the fuel filter? Thank you.
Post #567795 Sun Oct 28 2018 2:59pm
Brit Plumber
I don’t think the filter will have any wiring but it would be worth replacing if it hasn’t been serviced in a long time. If you mean fuel pump, I think there may be 2, one in the tank and one else where. The one in the tank is bound to be a PITA, because of where it is and how to get to it.
Try pulling the relay and trying another (could be the same type on another system you can swop out) or listen to see if you can hear it switching. 2019 5.0 SC SVA (Current)
Post #567799 Sun Oct 28 2018 3:28pm
paulwest16
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
Did you ever solve this problem and if so what was the outcome.
My sport is doing the same as what you have described yours doing. Had the same fault codes to.
Post #630963 Mon Feb 20 2023 5:32pm
RR-Panda
Australia 2012 Range Rover Sport 3.0 TDV6 HSE Lux Alaska White
@paulwest16
@newlove2003
Did either of you resolve this? I have the same issue - Please post your fix
Post #634698 Tue Aug 01 2023 6:00am
The original post is 5 years old, I think it unlikely you will get a response now from the O.P, but you may be lucky.
Post #634699 Tue Aug 01 2023 6:22am
paulwest16
Mine was the chain on the inlet on the passenger side broke. It a small chain that does the inlet cam not the main one that goes to the crank that’s why the engine was spinning ok still.
Post #634700 Tue Aug 01 2023 7:15am
RR-Panda
Hi Paul, thanks so much for your reply. I suppose a broken cam chain is better than a broken crank!!
I just rebuilt the engine, and reused the cam chains, but they seemed OK at the time, so hopefully that is not it, but not the end of the world if it is the problem.
Thanks again, Neil
Post #634701 Tue Aug 01 2023 7:22am
RR-Panda
Thanks Col
Post #634703 Tue Aug 01 2023 7:55am
Page 2 of 3 <123>
