Home > Technical > Hunter Wheel Alignment |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
There should be caster readings too, for a start. Looks like some inexperience from the operator perhaps. 2012 SDV6 - it's missing a couple of cylinders
Fri Oct 26 2018 4:11pm |
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 80 |
I thought the caster readings are there in Grey ink I could be wrong though... |
Fri Oct 26 2018 4:15pm |
I would have thought the settings are the same for diesel & petrol.All the readings are in the green but does the guy who did it have the car in the right mode for the alignment.?
Fri Oct 26 2018 4:49pm |
If you mean TTM yes I did that my self iid tool... |
Fri Oct 26 2018 4:57pm |
Were all the tyre pressures the same before he started.?That can make a difference.
Fri Oct 26 2018 5:02pm |
Well according to the printouts you’ve attached he’s used the L320 5.0 Normally aspirated and Diesal non active ARB settings. So if yours has dynamic response then it is incorrect. It’s also not what he’s told he’s used. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Oct 26 2018 5:50pm |
I thought all post 2010 were supercharged.it could be the data on the machine is wrong,I used to have the computerised aligner & sometimes it didn’t have the right info for the model/ year for car I was doing.
Fri Oct 26 2018 5:56pm |
To be honest me or the guy didn't check the tyre pressures will do that tomorrow before take it back again... |
Fri Oct 26 2018 5:59pm |
I meant all the pressures set to right pressure not all the same
Fri Oct 26 2018 6:05pm |
How can I tell if my RRS 3.0TDV6 2010 has dynamic response? Which settings should go for on Hunter machine if he can not find my RRS model and year? Thanks |
Fri Oct 26 2018 6:06pm |
Dynamic response is on a rocker switch near suspension settings,it should come up on dash with dynamic when activated iirc
Fri Oct 26 2018 6:11pm |
Will check that also what should tyre pressure be on 22" wheels with 285/35 tyres? Thanks |
I would put fronts to 36 & rears to 38psi.
Fri Oct 26 2018 6:13pm |
Thank you for your quick replies guys
Fri Oct 26 2018 6:17pm |
