Home > General > 2011 tdv6 won't start trying to crank and dies.
Page 1 of 3 123>
newlove2003
Hi I was driving my 2011 range range sport which at 88k and i went to a drive thru, parked up turned the car off, then pressed the button so I could watch tv, I watched tv for approx 15 mins, went to start the car and it started to shake and tried to crank over but then died back down. I had the aa out and nothing showed up on the computer They recovered it to my house the guy said sounds like the injector. I sent it to an indepenteded rr speacialst they also put it onto a rr computer but think they tried having my pants down saying they not to sure what it is. They after start taking my car a part and will run into maybe a thousand just to figure it out. It's now sat baxk in my garden. I've tried to start it again a few times there is no warning lights on the cash or when I press the accelerator nothing happens. Please help.
Post #567347 Sat Oct 20 2018 10:27pm
Disco_Mikey
Crank? Neutral
Post #567349 Sat Oct 20 2018 10:40pm
Brit Plumber
Did you get any fault codes from either of the garages? You’ve not given much detail to go on. But seeing as you had the TV on for 15 minutes before it broke down I would be tempted to give the battery a good charge/health check. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567350 Sat Oct 20 2018 10:42pm
newlove2003
I had my mate come up when it first happened to put jump leads on and still did the same thing, it's like it starts but doesn't get there, ill post a video tomorrow just working away. It missed it service by about 5 thousand miles could the fuel filter have anything to do with it? I've got a sheet with errors ill upload the faults tomorrow when back home. I checked the car right away and the oil was fine if that helps at all. When you say crank shaft is that a serious problem? Would it have shown up on a range rover computer?
Post #567353 Sun Oct 21 2018 12:00am
Brit Plumber
If it’s the crank that’s snapped, you’re looking at a new engine which puts you into write off territory. It’s a known issue and DM is pretty spot on with kind of stuff. I really hope it’s not. 2019 5.0 SC SVA (Current)
Post #567358 Sun Oct 21 2018 8:44am
newlove2003
Hiya would it have shown up on the computer from range rover? I've uploaded the links to the print outs to what was shown on the computer
https://unsee.cc/79e3c1f2/
https://unsee.cc/32e662f4/
https://unsee.cc/488bb7b3/
https://unsee.cc/8ea36cea/
Post #567387 Sun Oct 21 2018 5:42pm
Brit Plumber
There’s a lot of fault codes there. By comparison when I read mine for the first time I had 8 faults total. They also had times and dates with each fault which help with how relevant they are. 2019 5.0 SC SVA (Current)
Post #567391 Sun Oct 21 2018 6:20pm
newlove2003
Is it 100 percent the camshaft as the previous person says? Could it be the fuel filter or fuel pump or injector or could that not be it?
Post #567398 Sun Oct 21 2018 7:00pm
newlove2003
Ok I see these faults codes could it be any of these?
P010c-00 mass or volume air flow b circuit low
P0102-00 mass air flow circuit low input
P250a-92 engine oil level sensor
P0195-00 engine oil temp sensor
P0627-13 fuel pump a control circuit open
P00aa-17 intake air temp sensor 1
I see the fuel pump listed here could that be maybe the problem its trying to crank but cant? Just trying to see if it can be anything else before I pay 3k for it to get sorted .
Post #567400 Sun Oct 21 2018 7:33pm
Brit Plumber
I think it needs the codes clearing and then try and start the car and then monitor new codes. Those codes could have been there for years.
And yes it could quite easily be a crank failure. 2019 5.0 SC SVA (Current)
Post #567408 Sun Oct 21 2018 9:48pm
newlove2003
Hiya them codes are new codes mate the range rover speacialst garage said they cleared the codes and reread them.
Post #567416 Mon Oct 22 2018 8:13am
Brit Plumber
Wow, if they are new codes then that is a lot. My car has roughly 2 faults codes a month by comparison.
Does the car car crank over at all? 2019 5.0 SC SVA (Current)
Post #567417 Mon Oct 22 2018 8:32am
Disco_Mikey
None of those faults would stop the car from cranking.
You will need to see if the crank will turn a full 360 degrees by hand, to ensure it is not seized Sad
Post #567423 Mon Oct 22 2018 9:10am
newlove2003
I'll upload a video later on mate I dont no if im using the right terms and stuff
Post #567428 Mon Oct 22 2018 10:41am
newlove2003
And when u saying cranking what does that term actual mean. My car its like it nealry fires up but doesnt then dies back down.. I feel so lost with this car hoping it won't the engine checked on eBay 3k fitted ill cry for a month lol
Post #567437 Mon Oct 22 2018 12:18pm
Page 1 of 3 123>
