Home > General > 2011 tdv6 won't start trying to crank and dies. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Crank? |
Sat Oct 20 2018 9:40pm |
Did you get any fault codes from either of the garages? You’ve not given much detail to go on. But seeing as you had the TV on for 15 minutes before it broke down I would be tempted to give the battery a good charge/health check. 2019 5.0 SC SVA (Current)
Sat Oct 20 2018 9:42pm |
newlove2003 Member Since: 16 Apr 2015 Location: west yorkshire Posts: 24 |
I had my mate come up when it first happened to put jump leads on and still did the same thing, it's like it starts but doesn't get there, ill post a video tomorrow just working away. It missed it service by about 5 thousand miles could the fuel filter have anything to do with it? I've got a sheet with errors ill upload the faults tomorrow when back home. I checked the car right away and the oil was fine if that helps at all. When you say crank shaft is that a serious problem? Would it have shown up on a range rover computer? |
Sat Oct 20 2018 11:00pm |
If it’s the crank that’s snapped, you’re looking at a new engine which puts you into write off territory. It’s a known issue and DM is pretty spot on with kind of stuff. I really hope it’s not. 2019 5.0 SC SVA (Current)
Sun Oct 21 2018 7:44am |
Hiya would it have shown up on the computer from range rover? I've uploaded the links to the print outs to what was shown on the computer
Sun Oct 21 2018 4:42pm |
There’s a lot of fault codes there. By comparison when I read mine for the first time I had 8 faults total. They also had times and dates with each fault which help with how relevant they are. 2019 5.0 SC SVA (Current)
Sun Oct 21 2018 5:20pm |
Is it 100 percent the camshaft as the previous person says? Could it be the fuel filter or fuel pump or injector or could that not be it? |
Sun Oct 21 2018 6:00pm |
Ok I see these faults codes could it be any of these?
Sun Oct 21 2018 6:33pm |
I think it needs the codes clearing and then try and start the car and then monitor new codes. Those codes could have been there for years.
Sun Oct 21 2018 8:48pm |
Hiya them codes are new codes mate the range rover speacialst garage said they cleared the codes and reread them. |
Mon Oct 22 2018 7:13am |
Wow, if they are new codes then that is a lot. My car has roughly 2 faults codes a month by comparison.
Mon Oct 22 2018 7:32am |
None of those faults would stop the car from cranking.
Mon Oct 22 2018 8:10am |
I'll upload a video later on mate I dont no if im using the right terms and stuff |
Mon Oct 22 2018 9:41am |
And when u saying cranking what does that term actual mean. My car its like it nealry fires up but doesnt then dies back down.. I feel so lost with this car hoping it won't the engine checked on eBay 3k fitted ill cry for a month lol |
Mon Oct 22 2018 11:18am |
