![]() | Home > Maintenance & Modifications > Engine and Gearbox Undertray |
Descarl Member Since: 25 May 2018 Location: Exeter Posts: 9 ![]() ![]() |
Had my 2007 RRS 2.7tdv6 for a few months now and slowly working through all the issues, the one's I can find anyway. Managed to fix the reversing sensors and low coolant level error last weekend and going to fit some running boards this weekend. I'd also like to sort out the missing under trays (engine and gearbox) but I was wondering if anyone could provide some information first.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
Should use chimney clips not nuts. |
What are chimney clips? 2019 5.0 SC SVA (Current)
When eBay works you will see
I had 2 clips for the M6 nuts between the 2 guards which I still used. The nuts were on the outer bolts of the large guard and I don’t think there were ever anything but 2 nuts fitted. 2019 5.0 SC SVA (Current)
Factory ones don’t have nuts.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
2 10mm x 65mm long.
Mine certainly has nuts (2) fitted but is a facelift variant. Cheers Col |
Cols put the sizes up, that’s what I bought.
Ok. I guess newer ones have nuts. Bizarre |
The list of bolts I put up apply to a facelift car so they may well be different to the pre facelift model, will try and check. Would appear to be same bolts but the two nuts are as said actualy 10mm spring "U" clips on the earlier model.
All
