![]() | Home > General (L494) > Refurbish deployable steps |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
It's the first job I did - I noticed you have a 15.5my - is your RRS still under manufactures warranty if so there is a bulletin & they should be replaced FOC. If not they are easily removed - 2 hex bolts at front & 2 at rear hold them to the deployable brackets. I had mine stripped & repainted with a flexible paint used on truck beds - anti slip.
HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81 ![]() ![]() |
No unfortunately out of manufacturers warranty. I think it’s going to be a job to do while I’m off |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Hi Guys.
The bulletin is LTB00722 - ' Side Step Paint Delamination ' - give your stealer a bell & quote the reference & your concerns.
My car sat at the dealership since March and the side step is something I should have picked up. I’m going to call them anyway and quote the bulletin, I’m going to say it’s sometbing that should have been sorted under warranty. MY15.5 HSE - SDV6 - Santorini Black |
Hi Peachy.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1853 ![]() ![]() |
Have you registered on Topix, it will be lurking in there somewhere. 2023 P440e SE Dynamic on order -cancelled
Yes I'm in Topix will have a look.
Wow cheers peachy |
Hi Peachy.
Hi Guys.
Barclay Member Since: 11 Sep 2018 Location: Aberdeen Posts: 4 ![]() ![]() |
Hi Thomas, would you be so kind as to post a photo or send a pm of the wear on your steps?
Hi Barclay.
