![]() | Home > General > RR SPORT HSE TDV6 2.7 LOCKED UP SOLID |
Crank has snapped. Engine is scrap |
Markmarc Member Since: 08 Jul 2018 Location: Midlands Posts: 20 ![]() ![]() |
Thanks for the quick response but my head is wondering why there is no debris in the oil ,oil pan everything looks good no casing damage and the baffle plate looks ok ,could it be a torque converter failed and locked it up have you ever had this issue .when i originaly done a dianostic check it said it was stuck in second but i overlooked it as it was free wheeling but a failed touque would lock the engine .wouldnt it.ive attached a screen shot showing current gear in third but selector in park cheers m. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
best whip the bottom end of the engine off.
Snapped crank doesn't necessarily leave metal fragments in the sump,if it is a clean break...
I’d agree with Disco Mikey, the crank snapping would be an almost instant seize, a clean break will give very little in the way of debris and nothing else would get chance to grind with the result of debris. The gearbox in 2nd would also suggest it happened at slow speed, maybe even just about to move off as it often uses 2nd to start. 2019 5.0 SC SVA (Current)
you push the tailgate at the bottom, in the middle to close it.
I think you get a 2 year warranty.
Lol |
On a slightly lighter note i can say its a valuable asset to have sites like this and a credit to the people who run them..ive made several phone calls today to so called EXPERTS who are not interested in nothing but MONEY ! Its a embarrassment to people who are talented mechanics but dont run garages when youve got these people so called EXPERTS who try to b#@@$hit you on repairs and how the only way to do the job is there way..The truth of the mater is they never worked on another engine or veichle so they are scared of being wrong when suggestions are made .The truth of the mater is there FITTERS NOT MECHANICS..ps i know they are all not like that but up to now ive met a few. |
I wouldn't bother looking for fault codes.
Thanks for the links greatly appreciated cheers.m |
