Home > General > RR SPORT HSE TDV6 2.7 LOCKED UP SOLID |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Crank has snapped. Engine is scrap |
Mon Jul 09 2018 5:02am |
Markmarc Member Since: 08 Jul 2018 Location: Midlands Posts: 20 |
Thanks for the quick response but my head is wondering why there is no debris in the oil ,oil pan everything looks good no casing damage and the baffle plate looks ok ,could it be a torque converter failed and locked it up have you ever had this issue .when i originaly done a dianostic check it said it was stuck in second but i overlooked it as it was free wheeling but a failed touque would lock the engine .wouldnt it.ive attached a screen shot showing current gear in third but selector in park cheers m. |
Mon Jul 09 2018 11:02am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
best whip the bottom end of the engine off.
Mon Jul 09 2018 11:08am |
Snapped crank doesn't necessarily leave metal fragments in the sump,if it is a clean break...
Mon Jul 09 2018 4:12pm |
I’d agree with Disco Mikey, the crank snapping would be an almost instant seize, a clean break will give very little in the way of debris and nothing else would get chance to grind with the result of debris. The gearbox in 2nd would also suggest it happened at slow speed, maybe even just about to move off as it often uses 2nd to start. 2019 5.0 SC SVA (Current)
Mon Jul 09 2018 9:33pm |
A big thanks to the info and advice from all at least it settles my brain for 10 mins.I will pull off rest of the casing off to get a better look at the crank and damage if the crank has caught at low speed and maybe not yo much damage has anyone just replaced crank shell etc and got away with a light rebuild in situ of the bottom end. Cheers m.ps how the hell do you open a jammed tailgate its neither closedor open and the horn makes me jump out of my skin every night i lock it lol tbanks again. |
Mon Jul 09 2018 9:50pm |
you push the tailgate at the bottom, in the middle to close it.
Mon Jul 09 2018 9:59pm |
think it will be a second hand unit and strenghen as i go arp shells etc .cant justify a 5 k engine with weak cranks that could go at anytime .maybe a salvage jag thats been hit hard up the rear may be a cheaper solution will give the tailgate a shove at the bottom tommorow and see if it closes and then reopens on the button.cheers m. |
Mon Jul 09 2018 10:12pm |
I think you get a 2 year warranty.
Mon Jul 09 2018 10:50pm |
Lol just done the tailgate and now works as should lol neighbours were twitchung curtains lol just the easy engine build now and no doubt lots of helpfull help from this site xheers m.will get back with some photos tommorow on the crank situation . |
Mon Jul 09 2018 11:01pm |
my bad after having a good luck today ive found fine swarf in oil and little bits of shiney metal id say shells..maybe spun ? Overheated ? Still not took casing off yet been busy but might plug in diagnostics to see if theres any history on coolant faults.can anyone confirm pls if the crank can be pulled in situ.if its spun and got hot seized im wondering if can be done from underneath i get the impression looking at it it can be but rather ask.if not will pull the block with the body on .cheers m ps.with not knowing the history if what happened im secind guessing at the moment. It may have been low on oil or coolant and someones just toped it up after what had happened thinking it would cure it .cheers m. |
Tue Jul 10 2018 7:26pm |
On a slightly lighter note i can say its a valuable asset to have sites like this and a credit to the people who run them..ive made several phone calls today to so called EXPERTS who are not interested in nothing but MONEY ! Its a embarrassment to people who are talented mechanics but dont run garages when youve got these people so called EXPERTS who try to b#@@$hit you on repairs and how the only way to do the job is there way..The truth of the mater is they never worked on another engine or veichle so they are scared of being wrong when suggestions are made .The truth of the mater is there FITTERS NOT MECHANICS..ps i know they are all not like that but up to now ive met a few. |
Tue Jul 10 2018 8:33pm |
I wouldn't bother looking for fault codes.
Tue Jul 10 2018 8:49pm |
Thanks for the links greatly appreciated cheers.m |
Tue Jul 10 2018 8:59pm |
