![]() | Home > General > RR SPORT HSE TDV6 2.7 LOCKED UP SOLID |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Is the belt tensionner missing in drivers side ? No
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
That's a snapped crank. Breaks between cylinders 2/3, pushed the front end of the crank forwards, and fractures the oil pump casing
Markmarc Member Since: 08 Jul 2018 Location: Midlands Posts: 20 ![]() ![]() |
Hi .yes engine is painted black does that tell you its a recon or gen .pulleys were all there and intact ...i was thinking the crank has caused the crack being that low |
Yes with all that black paint it does point to a recon I would say. |
I would say going in for the third engine in a only a 100000 lifetime is not a good advert for these engines. |
Shame i cant find out whos fitted the engine and when was fitted it may be still under waranty that would have been a bonus lol .my heads ticking now im going off to do some research and check history on the documents ...ive found several cheap jags under 2k witb low miles and full service so will go looking and find the donor. |
check engine number v the logbook |
Hi Disco mikey or Andy my question is how much hassle is it to change ftom manual back to auto box ive found a jag 2.7 but manual .is it just the torque flywheel and bell housing? Is the bell house a straight bolt iff bolt on change cheers m. |
Hi Disco mikey ive picked up that 2.7 block sounds ok runs nice but what make shells would you recommend to replace existing ,Glyco.arp.king.etc i value your opinion cheers m. |
I would be tempted to just leave it alone if it sounds fine.
Hi Andy thanks for the info the jag is a 2005 110.000 mile good history to 80 ish and a 2 owner from new.shame to gas axe it up bit must needs |
You do hear the odd story of chain failure.
Markmarc.. I think you may find it beneficial to join the sister Disco3/4 forum. Those guys are more into the DIY stuff. This forum is great, however more into enjoying the cars than repairing. Remember Disco is a Sport in working clothes. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Just for starters
