![]() | Home > Technical > Air Conditioning |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Tim,
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 ![]() ![]() ![]() |
have you got the econ button pressed in as it does make a difference, if you have, turn it off and see if you get cool air. |
timajersey Member Since: 04 Jun 2005 Location: Jersey, Channel Islands Posts: 31 ![]() ![]() ![]() |
Thanks for the advice Andrew,
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
Have had mine back for a similar problem except it was the other way round cold air out of the windscreen vents when temp set to hot.
Mine went to the dealer yesterday and they have ordered a replacement `interior temepature sensor' (thermostat to you & me).
nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111 ![]() ![]() ![]() |
Hi Biggles , I seem to have the same issue. Using the heater , I have cool air coming out of the small vents above the controllable vents (does this make sense ?) . Is this the same issue that you had , if it was what was the solution and was it a long job at the dealers ? |
Over this past very cold weekend I wasn't sure that my heating was working quite as well as it should - the car did get warm eventually, but I had to manually set the temp, air direction and whack the fan speed right up. Using the auto function was next to useless. Another teething issue with the car, I suppose... no doubt sorted for next year's cars. |
I was back at the dealer this morning to have the new interior temperature sensor fitted - apparantly it was only after the third order attempt that the part was finally received.
Keep us posted Mr G. L319 D4 HSE
Seems like the Disco3 boys are having simililar problems.
