Home > Technical > Air Conditioning |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2581 |
Tim,
Sun Oct 30 2005 5:46pm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
have you got the econ button pressed in as it does make a difference, if you have, turn it off and see if you get cool air. |
Sun Oct 30 2005 7:51pm |
timajersey Member Since: 04 Jun 2005 Location: Jersey, Channel Islands Posts: 31 |
Thanks for the advice Andrew,
Sun Oct 30 2005 9:20pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Have had mine back for a similar problem except it was the other way round cold air out of the windscreen vents when temp set to hot.
Mon Oct 31 2005 8:55am |
Mine went to the dealer yesterday and they have ordered a replacement `interior temepature sensor' (thermostat to you & me).
Thu Nov 03 2005 12:18pm |
nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111 |
Hi Biggles , I seem to have the same issue. Using the heater , I have cool air coming out of the small vents above the controllable vents (does this make sense ?) . Is this the same issue that you had , if it was what was the solution and was it a long job at the dealers ? |
Mon Nov 21 2005 10:26am |
Over this past very cold weekend I wasn't sure that my heating was working quite as well as it should - the car did get warm eventually, but I had to manually set the temp, air direction and whack the fan speed right up. Using the auto function was next to useless. Another teething issue with the car, I suppose... no doubt sorted for next year's cars.
Mon Nov 21 2005 10:32am |
I was back at the dealer this morning to have the new interior temperature sensor fitted - apparantly it was only after the third order attempt that the part was finally received.
Mon Nov 21 2005 7:10pm |
Keep us posted Mr G. L319 D4 HSE
Mon Nov 21 2005 8:14pm |
Seems like the Disco3 boys are having simililar problems.
Tue Nov 22 2005 10:08am |
