Home > Technical > Suspension query. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
typical problem.
Thu Jun 28 2018 11:07am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
It lowered ok. Steve. |
Thu Jun 28 2018 11:08am |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Did it raise to off road height ? |
Thu Jun 28 2018 12:00pm |
Didn't try that. Steve. |
Thu Jun 28 2018 12:01pm |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 |
Mine used to do this... I would select the lowered position, it would go down, and then I would get a message saying that it has gone to offroad setting, and it would go up.
Thu Jun 28 2018 12:08pm |
Just tried it and it took ages just to raise to standard. Lowered again and it said access this time. Raising is slooooooo though. Steve. |
Thu Jun 28 2018 12:09pm |
I would check the state of your struts. Mine were badly rusted at the bottom. It used to raise very slowly.
Thu Jun 28 2018 12:12pm |
Sounds like you've got two issues, the slow to raise is down to your compressor going weak (gonna need servicing or replacing soon) and the access to offroad is either a calibration issue or a faulty ride height sensor. |
Thu Jun 28 2018 12:17pm |
The compressor was replaced before I had it...last September. Steve. |
Thu Jun 28 2018 12:18pm |
If it detects an obstruction under the car when you try to lower it , it will automatically raise to off road height .
Thu Jun 28 2018 12:19pm |
Hard reset? Steve. |
Thu Jun 28 2018 12:20pm |
Disconnect battery and touch positive and negative cables together (not the actual battery terminals)
Thu Jun 28 2018 12:26pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
make sure you leave it 20 mins before shorting the leads after disconnecting there is a warning in the maintenance procedures... |
Thu Jun 28 2018 12:41pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
[quote="DEVON"]Disconnect battery and touch positive and negative cables together (not the actual battery terminals)
Thu Jun 28 2018 1:45pm |
