Home > Technical > Suspension query.
Page 2 of 3 <123>
Cymruambyth
Wales
Just looked on you tube and it says to use a wire with a resistor...not just touch positive and negative Shocked Steve.
Post #560148 Thu Jun 28 2018 1:55pm
Brit Plumber
Just a thought and going back to what was said earlier, I assume the suspension must respond to an obstruction by sensing the drop to access is slowed or restricted. What if corrosion on the struts or suspension is increasing resistance, hence being slow and causing the ECU to think there’s a restriction to select off road height. Maybe all the suspension woes are interlinked, noises, slow and off road height when access selected? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560149 Thu Jun 28 2018 2:11pm
Cymruambyth
Wales
It didn`t try to reach off road. It actually dropped to access height as I wanted but the screen said it was in off road Shocked It went back to normal height but took ages. Haven`t tried off road height...didn`t want to push it!! Steve.
Post #560150 Thu Jun 28 2018 2:22pm
I don't think a battery reset will fix this. Not worth trying.
Yeah as said 2 issues. A leak in the system somewhere (or leak near compressor if new)
Leave it in standard for now.
The display says Off Road is because that is where it wants to get to, but the system it too tired to actually get there.
Post #560165 Thu Jun 28 2018 4:24pm
Cymruambyth
Wales
I tried it earlier with windows open and as it was rising I could hear air now and then so a leak may actually be the issue. Steve.
Post #560167 Thu Jun 28 2018 4:26pm
check for a noise under the passenger side (the tank)
Post #560175 Thu Jun 28 2018 5:07pm
Cymruambyth
Wales
Cheers guys. I`ve text the garage I use to give it the once over. Once THIS problem is sorted it`ll be going on ebay Thumbs Up Steve.
Post #560201 Thu Jun 28 2018 7:37pm
DEVON
That’s a pity cause you’ve sorted all its little quirks and problems , and now someone else will benefit .
These cars do test your patience though Whistle
Post #560208 Thu Jun 28 2018 8:17pm
Cymruambyth
Wales
I know mate...I did think that but I just can`t be doing with thinking, what next every time I drive it. I bought my dream car (E46 M3) and only kept it 12 months because of all the constant faults. Time to cut my losses Thumbs Up Steve.
Post #560209 Thu Jun 28 2018 8:19pm
DEVON
Well that’s fair enough mate ......
I hope your suspension problem is a cheep fix , like I said they do test your patience .
When they go wrong they are a pain , but when they are right they are brilliant Thumbs Up
Post #560212 Thu Jun 28 2018 8:29pm
Cymruambyth
Wales
I think I was spoilt with my Focus ST....3 and a half years and nothing broke....I don`t think I even changed pads Laughing
All I spent was what I wanted to, getting it to stage 2. I must admit, I regret selling it Steve.
Post #560214 Thu Jun 28 2018 8:39pm
RS focus won't even last a year without requiring a replacement engine or head gasket.
American design with materials changed.
Post #560216 Thu Jun 28 2018 8:47pm
Cymruambyth
Wales
Yeah the mk3 does nothing for me. Now...if I had a spare 20k...mk2, yes please Thumbs Up Steve.
Post #560218 Thu Jun 28 2018 8:48pm
Cymruambyth
Wales
Just been to my sister's house and parked half on her drive. So I thought get bro in law to sit in the sport and lower and raise it so I can listen for air or something. Worked fine...done....up, in seconds and again!!! Wtf? Steve.
Post #560277 Fri Jun 29 2018 7:36pm
DEVON
Rolling with laughter Rolling with laughter Rolling with laughter
Does that mean it’s not going on Ebay just yet ?
They do throw up some strange behavior sometimes , that drive you mad
Just like her indoors Whistle
Post #560280 Fri Jun 29 2018 8:38pm
Page 2 of 3 <123>
